MSI 694D Pro2-IR version2
  • Noble
    • Jan 2006
    • 6
    Hey guys!
    I had to register to the site and ask your opinnion about something, because you seem to know very much about these issues...
    I have about 2 years old msi 694D pro2 motherboard (version 2). It has been working like charm, but about 6 months ago it started to do weird powerdowns once in a while.
    After few hours of use computer may (and nowdays usually will) powerdown instantly without any warning. After this computer will not turn on from powerbutton if I press it normally. If press powerbutton only little and hold it somewhere in middle for some time and then press it again computer may wake up - sometimes soon, sometimes not so soon. Usually I need to repeat this procedure few times.
    What I've figured out so far:
    1. After unexpected powerdown powerbutton doesn't work normally even I would wait hours before trying to boot it up 1st time. If I shut computer down normally, it will powerup normally, without any problems. In other words heat is no factor in here.
    2. I have replaced power supply unit with more powerful one after problems started 1st time. It didn't help.
    3. I have replaced heatsinks and cpu fans without success.
    4. I have been monitoring temperatures and voltages with motherboard monitor and there is no peaks b4 the unexpected powerdown in the logs in any values.
    5. I have been monitoring the temperature of the case and it is no factor.
    6. Computer may experience unexpected powerdown while playing some game (high load) or while browsing the internet (low load), but very rarely (or maybe not at all), while computer is totally idle (or in suspend mode).
    7. While using computer hardisks go to powersave mode and wake up normally without problems.
    8. In nutcase. Computer works like charm, but suddenly it just powers off in a second. No warnings, no slowdowns, no exact time of day, not certain amount of uptime. This is totally unpredictable but happends more and more often every day.
    For you to know:
    1. After normal shutdown powerbutton works normally and computer boots up with single quick touch of the button as it should.
    2. Powerbutton is not busted (I switched it with reset button just in case.)
    3. I have replaced powercable. Nothing changed.
    4. On last effort I placed computer behind UPS. Nothing changed.
    5. Operating system is winxp pro sp2, dual 1gig p3, 896 megs of ram.
    6. All the components in motherboard look ok with bare eye. What is hapening inside? God knows
    If you guys have any idea what is going on, throw me with reply. I've been working with computers since c64, but never heard about this kind of problem b4.
    Thank you in advance.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: MSI 694D Pro2-IR version2
    So none of the caps around the CPU area look domed or leaking? Sure sounds like badcaps, and I would've guessed PSU first, but you've already replaced that. Odd...
    What are the brands of the caps on the motherboard?
    Ludicrous gibs!
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      its gotta be the caps. we have a few reports from the 694d series on this forum with badcaps. check what brands of caps are on your board.
      maybe post some pics and we can spot something you didnt?
      nice comprehensive report. i think you covered most things, only memtest86 ram testing you missed.
      • Noble
        • Jan 2006
        • 6
        One image talks more than words...
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          i see chemicon KZE (good) and teapo which can be bad, failing without visible signs. do you have any other cap brands on the board?
          • Noble
            • Jan 2006
            • 6
            Running the memory test on it now... takes a while
            As soon as I am able to get back to that computer again, I will send more pictures.
            btw... Is there any way to test those caps w/o actually removing them?
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              you need either esr meter or oscilloscope
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Wow... orbs! Haven't seen them in awhile...
                Ludicrous gibs!
                • Noble
                  • Jan 2006
                  • 6
                  Ok... I don't have those and can't get my hands on one :/
                  Anyways... memory test passed without errors.
                  Here are some more pictures - lemme know what you think
                  • cods69
                    • Oct 2005
                    • 92
                    The symptoms sure sound like a badcaps issue.
                    I'd be stripping everything off the board except the basics (vga cpu ram primaryHD) for elimination sake, then trying alternate ram sticks, vga cards etc. for more elimination.
                    I see in one of the pix that there is one cap that is particularly close to what looks like a COM port plate. Is/was there much movement in any caps that are in tight situations?
                    EDIT: actually, on second glance at the first photo in the group of six you have, do I see that smaller dark green cap of the 4 on the photo have a very slight bulge at the top - It just looks like a difference in reflection, and is that a extremely small brown spot in the middle?
                    Maybe it's just my eyes.....
                    • Newbie2
                      • Sep 2005
                      • 885
                      In the first pic I see a bulged Teapo cap.
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        Yep, a bulged and also possibly vented Teapo.
                        Ludicrous gibs!
                        • Noble
                          • Jan 2006
                          • 6
                          I doubt that any card/memory/drive could cause the powerdown/powerup failures, but I guess that I have to check that also...
                          Yes. That usb/eth connector cable is touching one of the caps, but very gently. I was really careful when I installed it in there in 1st place and made sure that I won't bend anything. There is no mechanical failure there.
                          Here is closeup picture of that cap you were talking about (?). It is the only one in entire mother board what doesn't have completelly flat surface on top. I agree that it looks slightly different than the others.
                          After making those elimination tests should I try to replace it and see what happens?
                          Thanks to all who have replied so far
                          • dood
                            Deputy dood
                            • Mar 2004
                            • 2462
                            Teapo caps are known to fail without showing any signs, and that one is certainly showing signs... I'd replace it and any other Teapo's on the board.
                            Ludicrous gibs!
                            • cods69
                              • Oct 2005
                              • 92
                              That is definitely a bad cap.
                              ...and so close to a CPU it's bound to cause problems.
                              • Chris1992
                                • Apr 2005
                                • 561
                                Yes, that cap is most definitely bad, replace it and all other Teapo and Tayeh. Leave the light green KZE caps. And nice CPU heatsinks. If replacing caps doesn't solve your problems, try swapping out memory: I don't know if Xelo chips are good.
                                The great capacitor showdown!
                                • Noble
                                  • Jan 2006
                                  • 6
                                  Okies. Thanks for answers to everyone!
                                  I will start seeking for replacements. We have couple component shops in town so hopefully I will get lucky.
                                  • davmax
                                    • Dec 2005
                                    • 899
                                    Be very careful at component shops. It is essential that you get the correct low impedance (low ESR) capacitors. The capacitance and voltage values are not enough on their own. You need to check other posts in this forum. Look for Panasonic, Nichicon, Rubycon.
                                    , United Chemicon or even Samxon brands. If in doubt please ask for help.
                                    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
                                    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
                                    160Gb WD SATAII Server grade
                                    Nvidia 8500GT 256Mb
                                    160Gb WD eSATAII Server grade for backup.
                                    Samsung 18x DVD writer
                                    Pioneer 16x DVD writer + 6x Dual layer
                                    33 way card reader
                                    Windows XP Pro SP3
                                    Thermaltake Matrix case with 430W Silent Power
                                    17" Benq FP737s LCD monitor
                                    HP Officejet Pro K5300 with refillable tanks
                                    • Mirenia
                                      Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                                      by Mirenia
                                      Hi everyone,
                                      got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                                      The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                                      If this happened once, then the laptop only runs for a few minutes until restart.
                                      This happens regardless while staying in windows or uefi or in a linux environment.
                                      At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                                      01-05-2025, 05:15 PM
                                    • hexadecimal
                                      HP 15-CB007NT - DAG75AMBAD0 REV:D powerdown after 4 seconds
                                      by hexadecimal
                                      hello, mainboard is KABYLAKE version and i tried all bios version,, when i write not kabylake bios: and ram removed board is power on, but powerdown after 4seconds when ram installed..
                                      kabylake version bios: powerdown 4sec ram installed or not installed..
                                      all core voltages ok.. rsmrst and powerok voltages ok..
                                      please help, thank you
                                      01-16-2023, 03:56 AM
                                    • Aetherone
                                      Blast from the past #2: MSI 694D-Pro A ver:1.0
                                      by Aetherone
                                      With the success of my Asus A8N32-SLI Deluxe recap project, I'm turning my attention to the other benchmark board in my history - the venerable MSI 694D-Pro A.
                                      Wayyyyyy back in the day, I paired one of these (in protoype orange PCB no less) with a pair of 366 Celerons for a world of fun. That board was flawless from day #1 (well, aside from the usual VIA issues with sound cards and Promise getting narky about additional HDD controllers). Wish I'd never sold it off.
                                      The current board is one of a hundred examples from a teaching college near the IT shop I used...
                                      01-15-2019, 10:32 AM
                                    • acata
                                      Asus L510MA/E410MA can't turn on with keyboard powerbutton
                                      by acata
                                      It's an Asus L510MA-DB02 with E410MA R2.1 motherboard. Its turn on when I unplugged the battery, and plugged the charger. But can't turn on with keyboard power button. The rest keyboard buttons working. I'm trying to find the board view for this motherboard but can't find it.
                                      Please help me to find the power button path. Or if you have the diagram and schematic would be great.
                                      Thanks in advance.....
                                      04-03-2023, 08:49 PM
                                    • amijim
                                      Lelon RXW MSI 694d repair !
                                      by amijim
                                      Hello Badcapers ,I am Amijim and I am about to change the caps on two ancient socket 370 dual motherboards from 2001 and I would like to you if the Lelon RXW low ESR caps I can find locally is a good replacement part.Also i would like to ask you what wuld be better ,change the original 2700μf caps to 3300μf or 2200μf? Thank you....
                                      04-02-2022, 12:09 AM
