Denon AVR-2308 no sound/video
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Anyone have this unit? All of a sudden all hdmi no signals, surround sound not working. Power is working fine, all relays clicks as they should. Only stereo sound works for tuner and RCA for L and R. As for hdmi, no sound or anything at all.
    Already checked all output transistors, seems fine. All fuses seems fine. I could only narrow it to the HDMI board as thats what processes the surround sound and HDMI signals.
  • madan1
    • Nov 2016
    • 719
    • Bulgaria
    Re: Denon AVR-2308 no sound/video
    Try heating the BGA chip.. just like this https://www.youtube.com/watch?v=0806W5jh_PY
    • DjKrish
      • Oct 2012
      • 354
      • SG
      The thing is nothing related to hdmi is working both audio and video. Even the rca video outputs not working. Only rca in audio works with stereo and direct. So that means the amp section has no fault. Clearly it narrows to hdmi board.
      • mmartell
        • Oct 2013
        • 3189
        The BGA chip IS on the HDMI board. However I have the same fault on an Onkyo and am suspecting the HDMI switch IC but have not yet confirmed it.
        In your case it's the Silicon Image IC top center. Try to find the datasheet and check if the voltages are present.
        • DjKrish
          • Oct 2012
          • 354
          • SG
          When i plug in hdmi input, it shows hdmi icon on the display n the amp. But no output.
          • mmartell
            • Oct 2013
            • 3189
            Haven't got a clue how the chip is designed to operate - it's possible yours is in a partial failure mode.
            • soeren
              A2442 - No sound over internal speakers and no video playback
              by soeren
              I am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
              All happened after the battery ran out of power overall several days when I was on vacation.
              I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery...
              07-26-2024, 01:24 AM
            • FuzzyOwl
              Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
              by FuzzyOwl
              Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
              Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
              Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
              I've followed the trouble shooting guide, audio check...
              12-05-2024, 11:54 AM
            • JRade
              Audio video receiver KENWood KR-V990D,no sound
              by JRade
              When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
              The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
              I replaced the capacitor C303/0.047F, nothing changes.
              I'm asking for help, what should I do next?
              Thanks in advance!...
              08-05-2025, 10:23 PM
            • karatzdi
              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
              by karatzdi
              I know some might say... just buy another one. Sell it as parts..!
              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
              Spent some time downloading the Service...
              06-11-2024, 08:38 AM
            • dansity
              Denon AVR 1912 no sound
              by dansity
              As a foreword I'm relatively novice with component level audio gear repair. My amplifier stopped producing sound and I currently have no funds to buy a new one so I need any help to repair it. I know "no sound" is one of the most common problem but there were other symptoms so some of you seasoned repairman might able to pinpoint the stuff I have to check. I did download the service manual from manualslib the "no sound checklist" is a bit intimidating.
              So i bought it working. First symptom: speaker protection relays on the audio board were clicking...
              05-06-2024, 10:16 AM
