Need Bios for Toshiba C855 - procesor upgrade turns off in 30 minutes
  • angel-boy
    • 550
    • Romania
    Need Bios for Toshiba C855-1DK
    I changed the processor from intel B820 to i3 2370M and laptop turns off in 30 minutes
    i understand that the bios is set to do this.
    mainbord is PLF / PLR / CSF / CSR UMA MB REV2.1
  • nazrul145
    • Jan 2014
    • 339
    • BD
    Re: Need Bios for Toshiba C855 - procesor upgrade turns off in 30 minutes
    Its not bios problem, I think your motherboard not supported this processor.
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      https://www.badcaps.net/forum/attach...0&d=1425472084
      Im Back... sort of...
      • angel-boy
        • 550
        • Romania
        what is the file F680.FD , is not a compatible bios file
        if not bios problem , what processor will my board support ?
        • shada
          • Feb 2015
          • 5
          • india
          its not a bios problem
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            @angel-boy
            rename to bios.rom or bios.bin
            • angel-boy
              • 550
              • Romania
              thanks, i will try tomorrow, hope will work !
              • angel-boy
                • 550
                • Romania
                not working , turns off in 30 minutes
                • angel-boy
                  • 550
                  • Romania
                  any help please ?.....................
                  • highpulse
                    i hate HP
                    • May 2013
                    • 1490
                    • portugal
                    Hi there ,
                    the problem is that the chipset you got on the motherboard does not support the cpu you have , it will ALWAYS shutdown around 30 minutes , you have no chance here , for bether details , chek the PCH chipset you have , and chek on intelwebpage for compatibility
                    i add this problem , after replacing a board , didnt noticed the PCH was another revision and the I5 cpu from the client didn't worked on that board , shuthing it down after 30 minutes , so ordered the best cpu available for the PCH i add on the board and working until now !
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1490
                      • portugal
                      you can trust on this info , simple chek the PCH , HM55 HM65 HM88 whatever is the revision , and confirm with intel webpage and you will see the cpu you're trying to add will not be supported
                      • angel-boy
                        • 550
                        • Romania
                        ok Thanks , topic can close.
                        • camel_git
                          • Apr 2014
                          • 1
                          • Spain
                          Hello. I am needing a bios dump for the kbc bios (power on) for this model. I have tried to extract it from the original toshiba file with no success. The mobo it is not powering on, and as far as I can go i guess the kbc bios it is corrupted. Can anyone help me??
                          Regards
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            post no 2 bios attached
                            • vedoza
                              • May 2015
                              • 37
                              • newyork
                              Hi dear friends,
                              toshiba Satalite c855
                              Power on
                              its not working display,does not display
                              pleas help
                                • 31304
                                is the laptop dead, or do you get a picture with an external monitor connected?
                                • vedoza
                                  • May 2015
                                  • 37
                                  • newyork
                                  yes because not display
                                  • soslaptop
                                    • Mar 2014
                                    • 3
                                    • algeria
                                    Its not bios problem but pdh sjtnv not supported this cpu
                                    • maha2005
                                      • Oct 2013
                                      • 20
                                      • tunisia
                                      thanks it's working
                                      • beydere
                                        • Nov 2020
                                        • 5
                                        • turkey
                                        Make clean me region bios
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          [Problem/ Request] Bricked TongFang GK7MRFR BIOS
                                          by cr4zychriss
                                          I am requesting urgent assistance to unbrick my laptop, a rebranded TongFang GK7MRFR chassis. The laptop is completely dead following a faulty in-OS EC flash attempt.
                                          I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details
                                          • Barebone / Chassis: TongFang GK7MRFR
                                          • MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • istvanszasz99
                                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                          by istvanszasz99
                                          Product Name: Razer Blade 15 (2022)
                                          Product ID: RZ09-0421
                                          Motherboard: CH580
                                          BIOS Versions I work with: 2.02 & 2.06
                                          Bios File Size: 32,768 KB
                                          Dear Forum Readers!
                                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                          !!! MY RAZER BLADE...
                                          11-24-2025, 05:52 PM
