Panasonic TC-50PU54 8 blinks picture flashes then dead
  • aasnowskate
    • 118
    • usa
    #41
    Re: Panasonic TC-50PU54 8 blinks picture flashes then dead
    I know. I appreciate all your time. Unless I order the C3 and SU/SD boards there is not much else I can do.
    • tw2005
      • Oct 2011
      • 6458
      If your concerned about the buffer boards you can take them out of the equation doing the buffer isolation and jumping the 2 pins on the SC50. I would not expect the SU/SD to give 8 blink though.
      There's not a lot on those c boards, I have had one with a bad 20 pin octal buffer IC.
      It had very high resistance pins 20(Vcc) - pin10(gnd) markings C541 and also VHCT541 which was the one I had bad and the larger profile of the 2.
      Looks like these only have the C541.
      I measured it board out but in cct comparing to another good C board pretty much all the same, but you could try installed but I'd disconnect any power leads, ribbons but leave the panel connectors alone. I think 1-2mohms, bad one was about 4 times that.
      From what I can tell UT50 has same panel boards.
      • aasnowskate
        • 118
        • usa
        #43
        I did the buffer isolation and jumped the sc50 pins. It tested good.
          As in, still 8 blinks?
          • tw2005
            • Oct 2011
            • 6458
            What! You disconnected the buffers from the SC, removed the earth screws, shorted SC50 and started normally with no blinks?
            That's totally unexpected for me anyway. Bad buffers should be 7 blinks.
            Maybe we should resistance test the buffer boards and see if we can prove anything wrong with them.
            • tw2005
              • Oct 2011
              • 6458
              post 1, Initially 8 blinks, ss disconnected, no blinks Chart says, SS11 SS33 disconnect, The TV Stays on With Black Screen suggests no blinks
              post 20, SC20 disconnected, 8 blinks charts says , SC20 disconnected, 8 Blinks
              post 28 SU/SD tested normal as per manual What did you do here, mearurement results?
              post 43 SU/SD isolation,SC50 test, OK (no blinks??) normal start, no picture,no blinks?
              • tw2005
                • Oct 2011
                • 6458
                Tom, I have a slight suspicion with my incomplete instructions, he may not have turned the TV on for the test.,The procedure is in the 2012 guide, hope he found it.
                I hope I'm wrong and he did turn it on and it powered up normally.
                • aasnowskate
                  • 118
                  • usa
                  #48
                  Easy guy, we are all on the same team here. I did plug it in with the sc50 jumped and still got 8 blinks. Sorry I was not clear about it.
                  • aasnowskate
                    • 118
                    • usa
                    #49
                    I should have stated my findings in that post with the jumper on.
                    • kenvwjetta
                      • Sep 2013
                      • 2
                      • united states
                      #50
                      My Tc-50pu54 just died and have the same 8 blinks problem. Did anyone find a fix for this? Thanks for any help.
                      Ken
                      • jmillsintacoma
                        • Oct 2013
                        • 1
                        Similar problem here. It's a Costco model TC-50PU54. Instant shutdown; 8 blinks.
                        If you disconnect the A33 ribbon to the SS panel, TV comes on. Stays on, and there is sound, no video (except a flash of the "HDMI1" panel in the upper left corner.
                        If you reconnect that A33 ribbon, you get the quick shut down and 8 blinks.
                        Put an ohm meter to the TP101 spot on the C1 panel and checked ohms to chassis. It reads almost none, so it's close to a short.
                        Everyone think that means a panel failure?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          You may have a shorted ic on the panel. One only other way to verify is pull the ribbons and visually blown
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Actually, is the picture normal during the flash?any vertical lines?
                            • kenvwjetta
                              • Sep 2013
                              • 2
                              • united states
                              #54
                              Thanks for responding. Does this mean that i have an expensive door stop?
                              I'm assuming that panel failure can't be fixed?
                              My tv shut down with the 8 blinks and came back on after a few minutes and work perfectly for a week before the second shut down.
                              I have not opened the tv yet because i was hoping that other people have a fix for it. I can see lots of ss and A boards for this tv on ebay to fix the 8 blink problem?
                              • jtscout80
                                • Nov 2013
                                • 1
                                Did you ever solve the issue, or scrap the unit?
                                I have a similar unit (TC-P50UT50) with what appears to be an identical problem, any insight would be appreciated.
                                • skillz83
                                  • Jan 2014
                                  • 1
                                  • usa
                                  #56
                                  I have the same problem with my Panasonic tc-p50u50 plasma. I unplugged the ss33 cable and it stayed on, but no picture. What now?
                                  • pb86
                                    • Feb 2014
                                    • 1
                                    I have TC-P50UT50 since Aug-2012 and all of a sudden yesterday TV went bad with 8 Blink behavior. I've extended warranty so trying to go through that first.
                                    But after searching through different Panasonic service manual, it seems like issue is with specific Transistor on SS Board. Most likely Q16051 which is most commonly used IGBT in Panasonic Plasma. Attached is the Panasonic Technical Bulletin and the exact part u can order.
                                    • R_J
                                      • Jun 2012
                                      • 9551
                                      I just repaired a TC-P50UT50 for 8 blinks, it was the shorted transistor, diode and open resistor as in the panasonic bulletin above, worked great after repair. Also I would check the grounds (board to panel) on the sc board, they were'nt the best either, clean with a bit of sand paper.
                                      • AnthonyR
                                        • Mar 2014
                                        • 1
                                        • Usa
                                        #59
                                        Where did u buy the replacement components?
                                        • mcf57
                                          • Mar 2014
                                          • 1
                                          I have a TC-P50UT50 as well. I got this TV in April 2012. First, I lost its two HDMI ports around August 2014. I was then watching my TiVo through its HD Component inputs until I could maybe get this repaired. Recently, I got the 8 blinks of death too and was not happy that it has already totally failed. I did not get the extended warranty either.
                                          I figured I had nothing to lose before I took it to a local repair shop so I called Panasonic up as an unhappy customer. I explained the situation and how I was not real pleased that two components on this TV failed within 2yrs of getting it. I have a Sony that is 3 yrs old with not a single problem and would consider Sony for my next HDTV purchase.
                                          Long story short....Panasonic gave me a case number and told me to take it to a local designated shop for repair (about 30mins away). Along with my receipt from best Buy, Panasonic will now cover most of the parts cost for both of these issues. It will only cost me about $150 in labor charges.
                                          I personally do not like getting extended warranties and realize they are gambles no matter how you look at it. I also figure I am still coming out ahead here as the GeekSquad warranty at the time was $200 for 2yrs.
                                          In case anyone else has this issue, you may want to try something similar. Can't hurt and only will require your time to make the phone call.
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                            11-20-2024, 08:52 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • FZG
                                            Panasonic AG-1000B VHS player with bad picture quality
                                            by FZG
                                            Hello!
                                            I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
                                            Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
                                            I want to know, is this something that could be solved by recapping or is the video head likely gone?
                                            Also, what mechanism is this?
                                            Any feedback is appreciated!...
                                            05-06-2024, 07:16 AM
                                          • Bazfletch3
                                            Panasonic TH-65FX800A backlight LED's working but picture is very dark
                                            by Bazfletch3
                                            Hi all
                                            While I have quite a decent background in electrical & electronic troubleshooting & repairs, this is my first time stripping down an LCD TV for repair.... I have inherited a 3yr old Panasonic LCD which has a picture, but it is quite dark (too dark to be watchable - but still quite easy to see; I didnt need a torch to see it).
                                            I started by checking and trying to adjust all of the picture and backlighting levels, but that made little to no difference. I also did a factory reset.
                                            From there I envisaged that the backlighting wasn't working, however...
                                            01-08-2024, 10:18 PM
                                          • kca
                                            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                            by kca
                                            Hello all ~
                                            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                            No picture. No sound.
                                            I tested all the voltages coming out of the power supply...
                                            10-12-2023, 05:23 PM
