List of pin compatible Laptop ICs
This is a sticky topic.
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    Re: List of pin compatible Laptop ICs
    found this interesting SIO interchangable
    http://hardware-today.com/articles/m..._o_controllers
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      That will come in handy, thanks for the tip!
      A working TV? How boring!
      • Ramee
        • Jul 2014
        • 218
        • Israel
        Thanks for sharing highpulse!
        • highpulse
          i hate HP
          • May 2013
          • 1489
          • portugal
          sure your welcome that why this community was created for we cam help each outhers
          • sopik78
            • Nov 2013
            • 519
            • Czech Republic
            Does anybody know if there is some Intel's chipset compatibility, NB and SB?
            • highpulse
              i hate HP
              • May 2013
              • 1489
              • portugal
              #26
              ISL 62883 compatible with ? ITS for cpu v core
              • ElectT
                • Apr 2012
                • 3
                • Portugal
                #27
                Originally posted by vvacl
                rt8206 = isl6237 = tps51427a (not isl6236)
                It depends if its RT8206 A or B.
                I almost bet the burn have happen because of mismatch in soldering placement.
                You must notice the point marking PIN1 and not the layout of the serigraphy written by the manufacture.
                If you notice the ISL don't have the text written in the same direction that RT.
                • ElectT
                  • Apr 2012
                  • 3
                  • Portugal
                  #28
                  Beside the pinout comparison and general specs you must check the LDO current.
                  A compatible IC may be able to boot up the motherboard but might shutdown when connected to the peripherals.
                  For example if a board was build with a 100mA LDO IC and you replace it with a 70mA LDO IC it might boot up, but when you connect the HDD it might shutdown.
                  • teknikbursa
                    • Sep 2014
                    • 64
                    • turkey
                    #29
                    Thank You
                    • highpulse
                      i hate HP
                      • May 2013
                      • 1489
                      • portugal
                      #30
                      yes well remembered ElectP
                      • sopik78
                        • Nov 2013
                        • 519
                        • Czech Republic
                        #31
                        What is ISL62392 compatible with? It's for 3.3/5V
                        • highpulse
                          i hate HP
                          • May 2013
                          • 1489
                          • portugal
                          #32
                          regarding to nvidia compatibility ,
                          i got a mcp67mv-a2 chipset that i have to order , but fuck 70 bucks for a new 2010 rev ? .--- i cheked that there is a possible compatibility with the mcp67MD-A2 ..
                          but they mention on the list
                          MCP67MV-A2
                          MCP67MV-A2
                          MCP67M-A2 and MCP67MD-A2 but only if external video is available
                          what does that mean , only if external video is available ?
                          thk in advance
                          and anyone interchanged them ? worked great ?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            #33
                            MCP67MV-A2 has the GPU core in it, MCP67MD-A2 does not. So MCP67MD will only replace MCP67MV if there is a separate GPU on the board.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1489
                              • portugal
                              #34
                              ok got the point thk mate
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1489
                                • portugal
                                #35
                                well also interested in knwoing that , since i got here a acer 7736zg motherboard and would like to know if it can e replaced with another .
                                • abbas_govani
                                  • Jul 2013
                                  • 89
                                  • India
                                  #36
                                  Originally posted by highpulse
                                  51123 can be replaced by 51125
                                  r u sure 51123 can be replaced with 51125 ?
                                  • smali
                                    • Sep 2014
                                    • 287
                                    • Pakistan
                                    #37
                                    all pin are ok but EN pin making problem.
                                    • sopik78
                                      • Nov 2013
                                      • 519
                                      • Czech Republic
                                      #38
                                      same problem and haven't find solution yet so I ordered ISL62392 from ebay
                                      • highpulse
                                        i hate HP
                                        • May 2013
                                        • 1489
                                        • portugal
                                        #39
                                        abbas_govani replaced it and i had any problems , if i posted it :P
                                        • highpulse
                                          i hate HP
                                          • May 2013
                                          • 1489
                                          • portugal
                                          #40
                                          RT8166b . any compatible for this CPU vcore ic ?
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
