Samsung LN52A650A Power cycling, squeal NEC-TONKIN caps
    Fixed this one in October 2015, it uses those NEC-TONKIN caps on the main board like other Samsungs that have bad C102.
    This main board does not have the C102 but has lots of the NEC-TONKIN NERAS7 (47uF 10V Tantalum) so I decided to replaced all of them and have been keeping in touch with the owner and the TV is still working fine as of today so I make this thread for future ref.
  • braxton
    • Nov 2009
    • 146
    Re: Samsung LN52A650A Power cycling, squeal NEC-TONKIN caps
    Thanks for the update budm!
    I did a quick test on my LN46A650 with power cycling problems by soldering in 6 X 100uF 25V electrolytic caps in parallel to the existing 6 NEC-TONKINS I could find on the upper side of the main board and so far so good- unit is working fine with no glitches or restarts!
    Will test for longer and update if I notice any problems.
      I did the same using lytics 100Uf 25V low ESR for testing first (same thing when I work on main board with C102 cap) to verify.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8327
        thanks for the update! I was actually wondering about that the other day...
        • braxton
          • Nov 2009
          • 146
          So unfortunately my problem came back. I've attached some pics of the issue I am having. First the picture starts out fine. At some point I get a few interference lines followed by a screen freakout with colors and lines and then the set reboots (never any squealing sound though). It may be fine for a bit after reboot or it may get a garbled pic and reboot again...
          I might try removing the Tonkin caps and just using the electrolytics since the old caps may be developing shorts or doing other weird things.
          Anything else I should be looking at? T-con? bad panel?
            Did you use low ESR caps or generic cap?
            You might as well get the rant caps from Digikey.
            • braxton
              • Nov 2009
              • 146
              I think they are Velleman (made in europe) generic caps.
              • braxton
                • Nov 2009
                • 146
                I think it is also worth mentioning that in my case, if I unplug the LVDS cable going into the t-con (but leave all other cables connected), the set will stay on indefinitely and will not reboot. Backlights stay on, but no image on screen since T-con is unplugged.
                Does this rule out the main board and suggest a T-con or panel issue, or could the main board still be suspect?
                • braxton
                  • Nov 2009
                  • 146
                  Another observation is that when the 4 ribbon cables going from the tcon to the lcd panel driver boards are removed but all other cables are plugged in, the set still power cycles, ruling out the lcd panel itself.
                  I think everything is pointing towards the T-con or the ribbon cable from the t-con to the main board, but most likely not the cable. It's just strange that the problem is sporadic. Maybe solder cracks or tin whiskers, but heating the board with a heatgun has no effect. Might try putting the tcon in the oven for a nice baking.
                  • braxton
                    • Nov 2009
                    • 146
                    what about the T-con caps at C120 and C2747 ect- see pic? They have 100 and A86 written on them. Anyone know their value?
                      100uF 10VDC, PANASONIC PTE series.
                      • braxton
                        • Nov 2009
                        • 146
                        Thanks! Since they are Panasonic they are likely OK. I wish I knew what was causing the sporadic reboot but I'm pretty sure it has something to do with the T-con. Happening more often now too. T-con for this model is hard to find and expensive, so hoping it might be repairable.
                        • nomoresonys
                          • 12276
                          • U.S.
                          Ever sort it out??
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            I know this problem it is a tcon board issue. There are 2 ram modules right above the main processor on the tcon that need to be re flowed with heat. The easiest way to find out would be to pull the metal cover off the tcon and heat up those 2 ram chips.
                            • nomoresonys
                              • 12276
                              • U.S.
                              Thanks Freakaftr8, it's so annoying when they just stop, unless they're in a coma lol, what's so hard about a small followup, referring to braxtons problem.
                                09-07-2024, 05:50 AM
                              • high-tech
                                Samsung UN55F7050AFXZA ver. TD01 power cycling
                                by high-tech
                                Hello everybody, I could use some help on this one... It's got me guessing...
                                I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                9. ground (PWM2) 10. 0.9 volts cycling...
                                09-15-2020, 03:39 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
