Lenovo T450s Bios bricked
  • 530v8
    • May 2019
    • 39
    After circuit SDA and SDL I have only black screen.
    Tried some Bios Dumps but getting 5 beeps pause 5 beeps
    FRU: 00HT748
    Somebody who can help?
  • 530v8
    • May 2019
    • 39
    Re: Lenovo T450s Bios bricked
    Somebody can repair original bios dump?
    When I flash back only the fn LED lights up and that's all. When I flash other dump it makes 5 beeps pause 5 beeps
      • 22024
      You should have waited for a reply in the other thread you posted in .
      https://www.badcaps.net/forum/showth...=65996&page=12
      • 530v8
        • May 2019
        • 39
        You right but dumping so much files so corrupt it now
        Trying to get to life
        • 530v8
          • May 2019
          • 39
          So I had 2 of t450s with bios pw .
          Made an dump of the working ThinkPad and flashed it to the bricked one with flashrom. Nothing happens it goes on keyboard backlit is working but no screen.
          Any other ideas?
          • 530v8
            • May 2019
            • 39
            Anybody knows if possible to flash only ec chip?
            • 530v8
              • May 2019
              • 39
              Ok had some luck maybe
              after flashing this dump attached
              it now boots up and says
              Bad CRC security settings in EFI Variable
              you can only type F1 for entering Setup but it wants an Password for this
              tried to indeed the lenovotransalteservice and bootoptions like threads before but no luck
              anyone an idea?
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1356
                • France
                anyone an idea?
                beep and no screen with patched version??
                try with button hold on the mainboard
                you have to wait before it lights up at least 30/45 sec.it will turn on and off several times by itself.
                • 530v8
                  • May 2019
                  • 39
                  i hold that switch
                  will wait
                  Screenshot attached
                  i replace lenovotranslateservice and PE32 Image Section "Replace as is "
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1356
                    • France
                    anyone an idea?
                    "T450s clean.rar"
                    it's bios OK or bios patched ?
                    • 530v8
                      • May 2019
                      • 39
                      Originally posted by Maxpower3
                      "T450s clean.rar"
                      thats an bios from forum that lights up the 450s
                      the original dump does not showing anything and not booting anymore
                      attached original dump
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1356
                        • France
                        try
                        no battery ,no cmos battery etc...
                        pass setup 1234
                        • 530v8
                          • May 2019
                          • 39
                          try
                          pass setup 1234
                          thanks will try it
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1356
                            • France
                            oops, i patched the original which doesn't work right ??
                            • 530v8
                              • May 2019
                              • 39
                              Yeah right this original doens´t work
                              but will try it again
                              • 530v8
                                • May 2019
                                • 39
                                so first dump not worked
                                only 5 beeps pause and 5 beeps
                                trying 2. dump
                                • 530v8
                                  • May 2019
                                  • 39
                                  second dump boots up but hangs on thinkpad logo nothing happens
                                  any idea?
                                  CMOS battery and all other batteries are removed
                                  Edit:
                                  Worked after pressing F1 so need to flash back the clean dump or what to do next?
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1356
                                    • France
                                    backup bios t450s clean
                                    • 530v8
                                      • May 2019
                                      • 39
                                      you have to press F1 to boot setup?? and nothing
                                      nothing happens it hangs with an _ sign
                                      Edit:
                                      try to flash t450s_clean dump back
                                      Where is my fault? Work with UEFITOOLS 0.26
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1356
                                        • France
                                        0.26 me too,just patched bootoptions and translate ,only body
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
                                        • lucaszmn
                                          Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                                          by lucaszmn
                                          Problem:
                                          I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                                          Initial Findings:
                                          • My current BIOS version is N1KET58W (1.45).
                                          • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                                          • I have the ability to use command-line tools on a Linux machine.
                                          Troubleshooting Steps & Conclusions:
                                          • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
                                        • Nicola Bianchi
                                          Lenovo x1 nano gen 1 -- bricked -- where to flash the bios/fw
                                          by Nicola Bianchi
                                          Hello!
                                          A few days ago I bricked my Lenovo x1 nano gen 1 while updating the bios/fw from linux.
                                          No the machine power up, but it stuck in a recovery state and I can not do much.
                                          Lenovo X1 Nano Gen 1
                                          Type: 20UN - X021US
                                          S/N: R9 - 10W2D9
                                          I would like to flash a new BIOS/FW on the chip using a CH341a programmer but ... I actually don't know which "chip" on the motherboard to target 🤦‍♂️
                                          So here I am to ask for help.
                                          I opened the laptop and I found a chip that may be the target, on it I've:
                                          Winbond 25R256...
                                          01-11-2025, 09:50 AM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
