2 Viewsonic VX1940W buzzing and no signal
  • wcperki
    • Dec 2010
    • 14
    The 2 Viewsonic X1940W LCD monitors I bought as a dual monitor set are both not working. They are still underwarranty but I could'nt help myself I had to take one apart. I could use some help getting the right caps ordered.
    I tried mouser and digikey but gave up. I'd prefer to just order from badcaps.net but here too I run into a roadblock with exact matches.
    I'd like to know what I can safely use to replace the following caps. Also, can anyone tell me how does one remove the epoxy glue inorder to de-solder?
    Pictures are attached.
    C1
    CapXon
    GF105
    P735 vent
    220μF 35v
    D=10mm x L=12mm x LEAD SPACE=5mm
    C302
    CapXon
    GF105
    P735 vent
    220μF 35v
    10mm x 12mm x 5mm
    C305
    CapXon
    GF 105 c
    P735 vent
    2200μF 10V
    13mm x 18mm x 5mm
    C307
    CapXon P735 vent
    KF 105c
    1000μF 10V
    8mm x 20mm x4mm
    C205
    KF105 P733
    50V 22μF
    5mm X 8MM x 3mm
    Thanks,
    Warren
  • wcperki
    • Dec 2010
    • 14
    Re: 2 Viewsonic VX1940W buzzing and no signal
    From what I found on the web these monitors share the same Back Light Inverter
    Power Input Board as my VIEWSONIC VX1940W model VS11868.
    Darfon b092-xx4h.b0920.001
    Westinghouse 27-D021625 Power Supply Unit
    Part Number 27-D021625
    Board Number(s) B092-XXX4H.B0920.001/D2
    TV Panel ManμFacturer Chi Mei
    Acer P191W and X193W
    VIEWSONIC VX1940W model VS11868, VP2030B, VX1962WM
    Westinghouse L1916HW
    • romansroad
      • 123
      You are going to fit in here so well!!! Under warranty and still taking them apart!!!
      Nice pics, and since you did them right (no inline) Plain Bill will be gratified as well.
      As to the glue, it just pops off most surfaces, leaving a slight residue on the board side. I use a dental tool, but a small flat head screwdriver is just fine. No need to reglue after recapping.
      As to which ones, I do see a bulge on the close ups of several, so, in general, replace all on the inverter board except the big one. It experiences lower frequency loads and usually doesn't fail. If it looks bad, however, do replace it. They can be $4 or so, which is usually the total for all the others combined.
      There was a recent post on step-by-step Digikey ordering which was really good....just can't recall who wrote it. Their site is daunting if you don't narrow it down early. I use Panasonics FM series for this application, and if you go to DIgikey, pick electrolytics, and them specify Panasonic FM. Then pick your voltage/capacitance and sizes from the now much shorter list. If the size is okay, you can always pick a higher voltage than your original, as it will slowly reform to the working voltage anyway. Don't go lower, and don't use 85 degree C caps....only the 105 degree C ones.
      Welcome aboard!
      • romansroad
        • 123
        Okay, I couldn't stand it.....here are the Digikey part #'s.....recheck the sizes as some were slightly off, but they should still fit.
        220uf/35v....... P12411-ND
        2200uf/10v.......P12357-ND
        1000/10v..........P12345-ND
        22/50v.............P12927-ND
        Have fun and keep us updated.....Be sure your soldering iron has the right heat range(s). Judging by your first post, you probablly already have this covered!
        • romansroad
          • 123
          Forgot....Digikey lists these under "aluminum" not electrolytics as I said first.
          • wcperki
            • Dec 2010
            • 14
            Taking things apart has always been a facination problem is It's not always possible to get stuff working again.
            • romansroad
              • 123
              Now that's the fun part.....never giving up!
              • wcperki
                • Dec 2010
                • 14
                Thanks, Looks like there is a typo. P12345-ND a 6.3v should be P12354-ND a 10 v. I found the "catalogue" this time which makes it easier to look things up.
                http://onlinecatalog.digikey.com/Web...PageLabel=1648
                Does one always keep same uF spec?
                • romansroad
                  • 123
                  Typo vs. dyslexia! Kidding!
                  The key to replacing the caps is the capacitance, so don't stray from the uf of the original. You can go up in voltage, and change sizes as the board allows.
                  Use Digikeys cheap USPS shipping option, not UPS or Fed Ex. Pretty fast shipping and low cost.
                  • wcperki
                    • Dec 2010
                    • 14
                    Something interesting, when I search under Panasonic part number EEU-FM1V221
                    it returns two capicators one is a 3000hr 1.24amp 41 38 mOhm the other a 4000hr 1.29amp 38 mOhm. Which to chose 4000hr Im guessing?
                    All prices are in US dollars.
                    Image Digi-Key Part Number Manufacturer Part Number Description Series Manufacturer Capacitance Voltage Rating Tolerance Lifetime @ Temp. Operating Temperature Features Ripple Current ESR (Equivalent Series Resistance) Impedance Mounting Type Package / Case Size / Dimension Height Lead Spacing Surface Mount Land Size Packaging Quantity Available Minimum Quantity Unit Price
                    P12412-ND EEU-FM1V221L CAP 220UF 35V ELECT FM RADIAL FM Panasonic - ECG 220uF 35V ±20% 3000 Hrs @ 105°C -40°C ~ 105°C General Purpose 1.24A - 41 mOhm Through Hole Radial, Can 0.315" Dia (8.00mm) 0.591" (15.00mm) 0.138" (3.50mm) - Bulk 13,680 1 0.50000
                    P12411-ND EEU-FM1V221 CAP 220UF 35V ELECT FM RADIAL FM Panasonic - ECG 220uF 35V ±20% 4000 Hrs @ 105°C -40°C ~ 105°C General Purpose 1.29A - 38 mOhm Through Hole Radial, Can 0.394" Dia (10.00mm) 0.492" (12.50mm) 0.197" (5.00mm) - Bulk 54,7
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Choose based on dimensions (form factor). Some Panasonic caps are available in standard (no suffix), short (S suffix) and tall (L suffix). Note: you profile doesn't indicate where you are. Digikey is very good if you are in the USA; not so good if you live outside North America.
                      PlainBill
                      • wcperki
                        • Dec 2010
                        • 14
                        Ok, attached is my parts list. I ordered one extra set for a friend who also has the same monitor
                        • romansroad
                          • 123
                          Very true on the USA aspect....missed that. I always wondered about the form factor codes.....thanks!
                          • romansroad
                            • 123
                            Less than $10 for each monitor and you should be back in business in no time.....NICE!
                            • wcperki
                              • Dec 2010
                              • 14
                              That was $11.29 total enough for 3 monitors so cost w/ tax + shipping is really only $3.77 for each monitor. I placed the order around noon and got confirmation it had shipped at 1:30 via U.S. Postal Service First Class Mail as you suggested. I expect to have parts by Friday or Saturday. Not bad, to me it's less hassel than finding shipping boxs, getting what is it a RMA, and shipping 2 monitors back for warranty work. Only question is what Viewsonic would have replaced or repaired my units.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Usually when a monitor is replaced under warranty the replacement is a refurbished unit. Often it's not even the same model monitor. That wouldn't be too bad if your 17" monitor was replaced with a 21" wide screen, but it doesn't usually happen that way.
                                PlainBill
                                • briand
                                  RocketScientist
                                  • Jan 2011
                                  • 12
                                  PlainBill
                                  you're right. ...but, then
                                  A while back, my ViewSonic VX922 was giving me fits... it'd take more and more "power on" cycles for it to actually come on. Eventually, it wouldn't come on at all. At that time, I had owned the monitor for 2 years and 360 days (that's right, 5 days shy of the 3-year warranty period). I guess I was feeling lazy, and I had a [borrowed] monitor to use in the interim, so I got the RMA and sent it off to ViewSonic. Two weeks later, they replaced it with a brand new (manufacture date was just a tad over a month prior to when it showed up on my doorstep!) ViewSonic VX1940w.
                                  For those keeping score at home, they replaced my (almost) 3-year old, 4 ms 19" 4:3 ratio monitor with a brand new 2 ms 19" 16:10 monitor, under warranty.
                                  ...which brings me here, today.
                                  I've had this monitor (VX1940w) now since August 2008. Under the terms of their warranty, it (despite being brand new) only came with a 5-day warranty (the unit sent inherits the remainder of the originally-purchased monitor's warranty). The day before yesterday, the screen went black. Subsequent attempts to power it on resulted in a very dim display, accompanied with the audible oscillation noted earlier in this thread, for 10-15 seconds, then back to black. ...a classic symptom of the "bad capacitors in the inverter" problem noted here.
                                  As much as I'd like to find an excuse to buy a new 22" or 24" widescreen monitor to replace it, my bank account would be significantly happier spending $5.00 or so to fix this monitor than to spend a couple hundred $ buying a new monitor. ...so, I guess I'm off to purchase a few caps, locate a clean butter knife from the kitchen, and get cozy with my desoldering and soldering stations for a few minutes.
                                  Thanks for this forum, and for allowing me to become a part of it. I hope that I can learn a few new tricks here while simultaneously sharing some of my acquired wisdom/knowledge to others.
                                  • briand
                                    RocketScientist
                                    • Jan 2011
                                    • 12
                                    okay, so a few hours later, and I've torn apart my VX1940w, and pulled out the power board. pic attached.
                                    two caps are clearly in need of replacement (220 uF 35V)
                                    I'm not sure about the other -- there's no bulging on the end, but the splitting of the plastic covering has me a bit concerned. should I just go ahead and order up a 120 uF 400V cap as well, and install it while I have everything apart?
                                    • jetadm123
                                      • 2169
                                      Yes, go ahead and replace it. It won't be that much more money. Definitely replace the other 3 small caps that aren't swollen. It's only a matter of time before they also fail.
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        It doesn't look too healthy in that picture with the plastic sleeve warped near the bottom. I would replace it. Capxon doesn't have the greatest respect on this forum.
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • dcbw
                                          PowerMac G5 ACBel 614-0303 buzzing
                                          by dcbw
                                          The PSU works, but shortly after powering on (either in the G5, or by shorting the power-on pin to ground) it begins buzzing loudly. It also makes the LED lights connected to the same circuit flicker. It's definitely a buzzing, not a high pitched whine.
                                          The buzzing seems to come from the high voltage side of the board, perhaps from the white relay. Could the relay be bad, or could the 5V supply be bad enough that it's unable to keep the relay on? Any pointers to help isolate the issue? Thanks!
                                          Other info: API2FS34, ID 291, Date B0404
                                          05-31-2024, 07:13 AM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • stvhop
                                          HP1955L Buzzing noise & interference
                                          by stvhop
                                          Hello, This is my first post so please forgive me if I miss out some vital info.
                                          I have a problem with my HP1955L monitor from 2005.
                                          The first thing to say is that it is still basically working, ie the picture is fine.
                                          However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
                                          The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
                                          11-07-2020, 07:13 AM
                                        • reessi
                                          Hanns-G HG281D - LCD Monitor - Low B/L voltage and loud buzzing...
                                          by reessi
                                          The pics are off the other really long thread as they are much clearer than my phone will do.
                                          The fault:
                                          In standby there is no buzzing.
                                          After signal input and turn on, a loud buzzing is emitted from the main transformer, no backlight.
                                          It is because the 24v line is at 21v irrespective of whether the inverter is plugged in. There is a picture on the screen.
                                          If you wait long enough the buzzing stops and the 24v line changes to 24v and the inverter comes on.
                                          I have checked every single cap on the psu and logic board by un-soldering...
                                          07-05-2020, 05:23 AM
                                        • StefanNg
                                          Viewsonic VX2718-PC-mhd SG2701B01-8
                                          by StefanNg
                                          Hi, Badcaps.
                                          I am troubleshooting a monitor
                                          Viewsonic VX2718-PC-mhd.
                                          Panel model SG2701BSG2701-8
                                          Symptoms is no image.
                                          This panel has 2 panel board connected by a U-ribbon.
                                          When I disconnected the ribbon, I get a perfect half screen image.
                                          I took some test point voltage, when ribbon disconnected.
                                          HVAA 8.38v
                                          FVDD12 1.21v
                                          FDD33 3.3v
                                          VIN 11.79v
                                          VAA 16.85v
                                          VGHF 30.16v
                                          VGL -8.02v
                                          CK1_I ~ CK8_I 1.403v
                                          CK1_L ~ CK8_L 8.26v
                                          When I connect both panel board
                                          HVAA, VGHF, and CKx_L...
                                          05-17-2025, 01:43 AM
