Vizio VO420E - No Video But Has Backlight,Sound.
  • dodadew
    • Apr 2014
    • 37
    Picked up a broken Vizio VO420E dirt cheap as I have the exact same model working now...figured worst case I have some spare parts, best case I have another TV which I also needed. Now the problem:
    Mainboard #0171-2271-3060
    Powersupply #0500-0407-0750
    Tv Turns on...Back-light lights up...nothing displaying on the screen whatsoever. Sound from HDMI works, yet there is no picture. It seems everything works, except displaying an image. The screen is just pitch black. Remote Works, Volume Buttons Work, Input button works (took a million presses to figure out where I was at)
    Power / Inverter board *was just replaced* by the previous owner as he thought it was a back-light problem...but had same problem with the new board. (Did not get an extra power supply to prove it, but someone was definitely inside the back of the TV).
    I took it apart and did some quick voltage checks @ the power supply. I have 5v, 12v. (don't remember the exact voltages, but I know they were less than .5v over, but none under. The 12v is taken while turning on. Doesn't fluctuate at all it seems. I visually checked the caps...none are bulging, burnt, or leaking. Checked the 2 fuses on mainbaord (F1,F2) and both are passing voltage (12v and 5v). I really have no idea where to go. Any insight would be greatly appreciative. I have been searching for hours, and can not find much that can help with my exact model.
  • audiofreak19
    • Apr 2013
    • 556
    • usa
    Re: Vizio VO420E - No Video But Has Backlight,Sound.
    I would say to check the t con.
      http://www.shopjimmy.com/media/catal...5542t06c17.jpg
      Check to see if you do have 12V on both ends of the SMD fuse F1, TV must be on.
      • dodadew
        • Apr 2014
        • 37
        Well I rechecked a bunch of things. First off, I have
        F1: 5.168vdc/5.151vdc (ON)
        F2: 12.29vdc/12.29vdc (ON)
        Power @ the Power Supply:
        HTML Code:
        +5_1: 5.212vdc (OFF) - 5.189vdc (ON)
        +5_2: 5.212vdc (OFF) - 5.189vdc (ON)
        +5_3: 5.212vdc (OFF) - 5.189vdc (ON)
        SGND_1: 0vdc (OFF) / 0.4ohms - -0.007vdc (ON)
        SGND_2: 0vdc (OFF) / 0.4ohms - -0.007vdc (ON)
        SGND_3: 0vdc (OFF) / 0.4ohms- -0.007vdc (ON)
        SGND_4: 0vdc (OFF) / 0.4ohms - -0.007vdc (ON)
        SGND_5: 0vdc (OFF) / 0.4ohms - -0.007vdc (ON)
        +12_1: 0vdc (OFF) - 12.29vdc (ON)
        +12_2: 0vdc (OFF) - 12.29vdc (ON)
        +12_3: 0vdc (OFF) - 12.29vdc (ON)
        PS_On: 2.264vdc (ON)
        I also checked some other things: ( I was not thinking and forgot to check the tabs as well)
        HTML Code:
        U2 (1117)  - In 5.111 / Out 3.292 / ADJ 2.046
        U5 (1117)  - GND 1.365 / OUT 2.612 / IN 5.113
        U7 (G1084) - 5.115 / 2.069
        U8 (1117)  - GND 0.001 / OUT 1.250 / IN 3.303
        U9 (1117)  - GND 1.248 / OUT 2.495 / IN 5.115
        U11(7805)  - In: 12.28 Ground: 0 Out: 5.012
        TU31 (EH13A) - 0.000 / OUT 0.426 / IN 0.021
        The voltages at TU31 seem off to me. Guess try to trace back and see where it gets its supply from as there is virtually nothing there?
        Also, do you think it would be feasible to take apart my known working one and swap mainboard (if its the same version) to see if the problem is actually in the LCD? (Without knowledge of this TVs past, im worried that could be it) I don't see any marks at all in it, but trying to make sure I am barking up the correct tree.
          Well, you still did not check the voltage on the SMD fuse on the T-CON board as I suggested in post #3.
          • dodadew
            • Apr 2014
            • 37
            OK, do you have some insight into where that would be located? Because I was assuming it was integrated into my mainboard as I only have a Power supply, and a Mainboard in the back of there. Power goes into Mainboard...2 ribbons come from the Mainboard and connect to the Driver Boards on the top of the LCD. I am sorry if I am not noticing something here, but I can seem to see where this would be? I guess I assumed that the top section of my mainbaord was an integrated T-Con as it has most its components prefixed by TC. (Pic in 1st post) I will tear it apart again in the morning and see what I am missing. I just looked at the service manual and don't see it listed...Do I have the one VO420 without an external T-Con Board?
            • dodadew
              • Apr 2014
              • 37
              I did some searching of pictures...and see a fuse I did not check..Labeled TF and circled in the pic. I think this is the equivalent of the one on the actual T-Con Board...Do you? I will give it a test tomorrow. Or maybe I am blind and there is an external T-Con board in here somewhere that I cant see. Either way Input still accepted and I will post back update tomorrow morning.
                "Do I have the one VO420 without an external T-Con Board?" It looks like it after I did more search on your model. Your version does not use the AUOPTO LCD panel.
                Can you see the label for this LCD panel you have? We can try locating the spec sheet for this panel.
                Yes, that is another SMD fuse.
                The empty J8 on the board looks like an option for installing the LVDS connector for the external T-CON board version.
                • dodadew
                  • Apr 2014
                  • 37
                  I will pop it open and have an answer in about 10 minutes. Thanks for the help thus far too.
                  • dodadew
                    • Apr 2014
                    • 37
                    LCD is LC420WUG (SB) (R1) (Pic Attached)
                    I Also checked that fuse...all was Good, but does not seem to be getting the 12v it wants. 12.29 is passing thru FU to U21 (4953GM) out of there to L57 (In at 12.29, Out @ .8-1.1V Fluctuating) then into TF. Now...what is L57. No markings does not help either.
                    • dodadew
                      • Apr 2014
                      • 37
                      After some quick research i think L57 is a ferrite bead. Does anyone think that a jump across it would work for testing? I'm not going to try it until I do some more research though.
                        "U21 (4953GM)" seems to be the switched MOSFET for providing the voltage to the circuit, it is turn on by the processor on the main board. L57 should show <1 Ohm. You can try disconnect those two white ribbon going to the panel to see if the 12V will come up.
                        • dodadew
                          • Apr 2014
                          • 37
                          The 12 v does not come up after L57. Shows 12 in... And 0 from turn on until Backlight lights... Then climbs from 6v to 8.4v. This is with white ribbons unhooked. L57 has a reading of 8.7kohm. From output of U21 to out of TF1 same reading. Starts out at 10kohm and settles down at 8.7kohm. Same with ribbons connected.
                            "L57 has a reading of 8.7kohm" That does not look right at all, I expect <1 Ohm. You can see L16 which is the smaller FB, check that. It looks to me you do have bad FB. Look around the board to see if you can locate anther FB withe same physical size.
                            • dodadew
                              • Apr 2014
                              • 37
                              L16 comes in at 0.4ohm...various other ones also come in under 1 ohm. Still looking for one about the same physical size.
                                OK, let find out if the L57 goes high resistance due to short in the circuits or not, check the resistance reading between one end of the fuse (the one with N) and the chassis ground to see what you read.
                                • dodadew
                                  • Apr 2014
                                  • 37
                                  Testing Fuse (N) to Ground...Starts up high and settles down to 7.7kohm. Testing from Fuse(N) to opposite end (U21 Side) of Ferrite L57 I get 0.992Kohm.
                                    OK, so there is no shorts circuit after the fuse (but can be shorts after the active circuits), and since the fuse is not blown, you can put your meter in DC A mode and put each probe on each end of the L57, you may want to solder wires to each end of the L57 so they can easily be connected to your meter and not worrying about probes slippage and short things out. We will wan to the current draw on the meter and see if you will get the pictures back on the screen. I do not expect the current reading to be more than 2~3A. You know how to use the meter in DC current testing mode, right?
                                    • dodadew
                                      • Apr 2014
                                      • 37
                                      I sure do. Ill solder on some leads and get a reading right quick. Thanks for the expertise again...would not be this far without your help.
                                      • dodadew
                                        • Apr 2014
                                        • 37
                                        Progress. I get 0.52amps immediatley after the backlight turns on ...displaying the vizio logo!!!...and I when it goes to the cherished blue screen, I get 0.78a. When I remove the probe from L57 with the set on...I lose video, and I assume the processor resets as the backlight turns off then back on. Should I get a reading with a video source / white screen as well?
                                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                                          09-12-2024, 02:00 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • SolarFlare
                                          Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                                          by SolarFlare
                                          My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                                          The TCON board has the following Chips -
                                          Samsung VTU63A0
                                          RT6939 - 2nos.
                                          and all these chips are getting real hot within a minute, I dont know if this is normal....
                                          06-26-2022, 08:58 AM
                                          GeForce RTX2080 Super Aero video gaming card issues help need
                                          by sam_sam_sam
                                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                                          05-07-2023, 08:12 AM
                                        • bobbyskillz
                                          Vizio E241i-a1 - works, but OSD stuck and no buttons work
                                          by bobbyskillz
                                          Hello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
                                          I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
                                          Thanks for...
                                          07-02-2025, 03:43 PM
