samsung PN43D450A2D relay clicking no sound no picture
  • jose6326
    • May 2013
    • 707
    So when I plug in the power cord the relay on the psu just clicks a few times and the green led on the logic board blinks then goes off
    Red standby light is on
    When i press the power button on the remote the relay clicks a few times again
    I tested the vs, va and vsc with all boards connected and I get a 0.000 reading
    I disconnected all the boards and plugged the power cord to the psu and I get a 0.000 reading again on va, vs, and vsc
    So I connected the main board only to the psu powered it and now I get the samsung chime/melody when I power it on. And I get one click from the relay on the psu and about after 10-15 seconds the relay clicks once and it powers off. I still get 0.000 on vs, va, and vsc with main board connected
  • jose6326
    • May 2013
    • 707
    Re: samsung PN43D450A2D relay clicking no sound no picture
    Here is the board lay out
    No visible defective components
    I still have to remove the boards to inspect the bottom side
    • R_J
      • Jun 2012
      • 9514
      I just was working on one of these, check the Z-(x)sus (last picture) there are usually 4 transistors shorted and they usuall replace the drive ic,
      4 - RJP30H2A
      1 -TND315 ic
      Then update the firmware after the repair.
      • jose6326
        • May 2013
        • 707
        I disconnected the cables to the logic board to the main board and the y board and the tv stays powered on. But I don't see any glow on the panel
        • jose6326
          • May 2013
          • 707
          4 - RJP30H2A
          1 -TND315 ic
          Are you talking about the ymain board or the x main board?
            You will not see panel glow with a Y-main is disconnected. Anyway these Samsung panels will shut down if the X-main or Y-main is missing. Just check for shorted transistors on the X-main, as R_J says it's a common fault.
            • jose6326
              • May 2013
              • 707
              Where are the transistors on the xmain? I dont see it
              Are you talking about the 2 on the heat sink?
              • jose6326
                • May 2013
                • 707
                I found four RJP30H1
                • jose6326
                  • May 2013
                  • 707
                  How difficult is it to replace the ic driver?
                  I dint think I can do it since it is so small
                  I dont have a small soldering tip
                  Also digikey does not have the tnd315 ic driver in stock and I cant find the RJP301h1 at digikey either
                  What is the other website I can buy these from?
                    Test all the transistors, the RJPs fail most often but not always.
                    • jose6326
                      • May 2013
                      • 707
                      Tom just to refresh I place the negative lead on one leg and the positive on the other 2 legs and reverse the procedure to test the transistors?
                      Can I test these on the board?
                        Test all three combinations of pins: 1-2, 2-3 and 1-3; the polarity doesn't matter for now, you're just looking for short circuits.
                        They can be tested in circuit.
                        • jose6326
                          • May 2013
                          • 707
                          Here is what I got
                          2, 3 - 0.1
                          1, 3 - 0.1
                          Same as #1
                          Same as #1
                          Same as #1
                          Same as #1
                          Same as #1
                          2, 3 - 4.83
                          1, 3 - 12.60 and goes up
                          1, 2 - OFL
                          2, 3 - 4.69
                          1, 3 - 19.81
                          1, 2 - OFL
                          2, 3 - 4.81
                          1, 3 - 20.39
                          • R_J
                            • Jun 2012
                            • 9514
                            Numbers 1 and 6 are probably ok, you need to remove the small legs of the transistors 2-5 as they are connected in parallel. There are kits available on internet
                              No, to me, looks like 1-6 all shorted.
                              You will need reasonable soldering skills to replace the FETs and the driver IC. It's not necessarily about a small tip - that helps - your iron must also hold temperature well, so it really needs to be temperature regulated.
                              I think you can buy all the bits from eBay.
                              • jose6326
                                • May 2013
                                • 707
                                I will try to find the fets and ic on digikey
                                My soldering skills are decent im just worried about the ic driver
                                If I can find a cheap replacement board I will just buy yhat instead
                                • jose6326
                                  • May 2013
                                  • 707
                                  I tested these on the "ohm" setting on my meter
                                  just making sure I did this correctly
                                  I am having a difficult time finding these parts on digikey
                                  • jose6326
                                    • May 2013
                                    • 707
                                    I ordered the repair kit with the 4 fets and ic driver from ebay
                                    but they do not have the other 2 fets I need and I checked digikey they do not have them on their website
                                    anyone know where I can buy these
                                    • jose6326
                                      • May 2013
                                      • 707
                                      Ok so I replaced the the faulty components
                                      When I plugged in the power cord the tv started up with the samsung chime, psu started clicking then I heard a small pop and magic smoke coming from the xmain board near the capacitors
                                      But I do not see any burn marks or blown components
                                      Im just going to order a new board
                                      I will retest the components I replaced to see if they were damaged
                                      • tw2005
                                        • Oct 2011
                                        • 6457
                                        Usually the easiest way, may be worth having a poke around the ymain too since the X & Y are connected to each other. I've had a X take out the y in a C series and have that shorted
