Need Bios Dump G62-B97EP
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello i need this bios Dump ,
    mainboard. p\n. 01013TM00-600-g
    PM_A_HPC_S MV_MB_V1
    Thanks in advance
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Need Bios Dump G62-B97EP
    from hp web site
    if no working you found an other dump here
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      the second
      • dmartins
        David M
        • Apr 2014
        • 197
        • Lisbon
        Yesterday I downloaded the HP version and the computer dont work anymore.. no power...
        With your dump the computer works but still without image and the power button dont shutdown the computer.. ( computer restart and the fan spins a lot )
        Maybe a no good dump ?
        Thanks in advance
        • dmartins
          David M
          • Apr 2014
          • 197
          • Lisbon
          This is my backup
          • ridamouh159
            • Nov 2014
            • 365
            • maroc
            here is another working dumps
            not for G62-B97EP for the same bid and working for you sure .
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              use another ic bios .
              and flash it
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                I used another IC and now the computer works ,
                Problem Solved ,
                Thanks ridamouh159
                • whitevolf
                  • Feb 2014
                  • 123
                  • TÜRKİYE
                  thanks
                  • tugrul63
                    • May 2015
                    • 94
                    • türkiye
                    and flash it
                    i do not understant. so lets change the bios chip?
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • Habble7
                      I need a BIOS dump for the Samsung S49CG934SU monitor
                      by Habble7
                      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                      Suspected Cause:
                      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                      by haitham sharabati
                      Hello engineers 😀,
                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                      💀 Problem:😅
                      - Device shows “Administrator Password”...
                      08-07-2025, 04:54 AM
                    • Citymin
                      NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                      by Citymin
                      My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                      The charging red LED lights up, but the charging screen doesn't show any indication.
                      When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                      (I've tried removing the battery and resetting the device, but the issue persists.)
                      NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                      PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • DynaxSC
                      MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                      by DynaxSC
                      Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                      I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                      11-17-2023, 10:56 AM
