Need Bios Dump G62-B97EP
  • dmartins
    David M
    • Apr 2014
    • 197
    • Lisbon
    Hello i need this bios Dump ,
    mainboard. p\n. 01013TM00-600-g
    PM_A_HPC_S MV_MB_V1
    Thanks in advance
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Need Bios Dump G62-B97EP
    from hp web site
    if no working you found an other dump here
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      the second
      • dmartins
        David M
        • Apr 2014
        • 197
        • Lisbon
        Yesterday I downloaded the HP version and the computer dont work anymore.. no power...
        With your dump the computer works but still without image and the power button dont shutdown the computer.. ( computer restart and the fan spins a lot )
        Maybe a no good dump ?
        Thanks in advance
        • dmartins
          David M
          • Apr 2014
          • 197
          • Lisbon
          This is my backup
          • ridamouh159
            • Nov 2014
            • 365
            • maroc
            here is another working dumps
            not for G62-B97EP for the same bid and working for you sure .
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              use another ic bios .
              and flash it
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                I used another IC and now the computer works ,
                Problem Solved ,
                Thanks ridamouh159
                • whitevolf
                  • Feb 2014
                  • 122
                  • TÜRKİYE
                  thanks
                  • tugrul63
                    • May 2015
                    • 94
                    • türkiye
                    and flash it
                    i do not understant. so lets change the bios chip?
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      Today, 05:12 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • MDSI
                      HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                      by MDSI
                      I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                      Details:
                      Model : HP OMEN 17-an012nf
                      Motherboard Part Number : DAG3BAMBAF0 REV : F
                      Serial Number (S/N) : 5CD7280D51
                      BIOS chip : Winbond W25Q64VSIQ
                      Programmer : EZP2023+
                      Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                      I already...
                      07-28-2025, 07:11 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
