ECS H61h2-m2 rev:1.0 bios
  • Blackam8899
    • Sep 2020
    • 46
    • Rosario
    Re: ECS H61h2-m2 rev:1.0 bios
    Tankyou! my friends
    • adrarian
      • Aug 2017
      • 7
      • algeria
      thank you
      • protocol
        • Jan 2023
        • 6
        • Philippines
        Originally posted by Matt Mat
        Thanks to this post I was able to rescue a bricked board after a bad flash. You da man.
        Hello how do you recover from a bad flash? I can explore BIOS but wont boot on any device. Just hangs up after logo of ecs is shown. The old version bin is 2.5mb, this one is 4mb. My board is P63 but I explored the back up ROM and it says H61H2-m2 so i tried this BIOS. TIA
          • 22161
          Post pictures of the motherboard model number.
          • protocol
            • Jan 2023
            • 6
            • Philippines
            It has no label on motherboard. I attached the picture of the previous firmware version.
            Here is the link of the motherboard.
            http://www.ascendtech.us/pcchips-p63...pcchipsp6.aspx
            Edit: Btw this tool gives me error about ME_UNLOCK not shorted but I already shorted it so I was force to flash the bios manually. https://campaign.ecs.com.tw/support/...osupgrade.html
              • 22161
              The board has been flashed with the wrong bios ! .If your motherboard is the same as the one in the picture you posted "PCChips P63G" start a new thread and request the bios.
              • protocol
                • Jan 2023
                • 6
                • Philippines
                #27
                Fixed it by reflashing the BIOS using CH341A with same BIOS ROM posted here. The H61H2-M2 V1.0 (10-17-2012).BIN
                Thank you!
                • kusal
                  • Jul 2021
                  • 28
                  • Sri Lanka
                  #28
                  SMDFlea​ seve the day thnx
                  • kusal
                    • Jul 2021
                    • 28
                    • Sri Lanka
                    #29
                    its 3rd gen supported tested confirmed
                    • Wr8th
                      • Dec 2024
                      • 2
                      So I've little experience updating BIOSes and am trying to update the BIOS on an old ECS H61H2-M2 1.0 motherboard so I can use an i7-3770 CPU with it.
                      Got the latest eBLU BIOS Live Update software but all it does is keep giving me a "connection to ECS server fail" message and won't let me do anything.
                      Have a couple of BIOS BIN files for the motherboard but can't find a way to select them in the eBLU program.
                      How can I install the BIOS update without the eBLU software?
                      Thanks in advance!
                        SMDFlea commented
                        Editing a comment
                        Thread merged.
                      • 22161
                      Thanks in advance!
                      Go to ECS support - https://www.ecs.com.tw/en/Product/Mo..._V1.0/download ,on the drop down list under Driver / BIOS & Others Download there is BIOS/Image & Manual/EDM at the bottom. Select that and you`ll see 2 bios updates,. Read the Update Description​ carefully about the ME warning and check your ME version before installing any of the bios updates.
                      • Wr8th
                        • Dec 2024
                        • 2
                        Hi and thanks SMDflea!
                        Followed the instructions and ran the CPU EVO II for the motherboard to update first (since the board BIOS shows the ME version at 7.0.4.1197). Finished and it updated the BIOS seemingly well, new settings were there and set everything properly, and it rebooted and the Windows 10 SSD that worked before entered automatic repair mode. Walked away for a bit and came back a few minutes later to find the PC had restarted and wouldn't load to bios, with the computer turning off and turning back on every few minutes. Now it just runs continuously after powering on without going to BIOS, and with no keyboard response.
                        Removing the RAM has the computer giving three short POST beeps in sequence, which stopped once put back in. Replaced it with a few other supported DDR3 sticks but it didn't make a difference. Nothing seems to make a difference. Swapped the PSU to no effect. Replaced the CPU (i7-2600) with a few other gen 2 CPUS I have, but nothing changed.
                        Any advice would be greatly appreciated, since I'm at wits end.
                          SMDFlea commented
                          Editing a comment
                          Sorry i didn`t see this post until now. Upating the bios is always risky. I can only suggest that you buy an SPI programmer and flash one of the bios in this thread.
                      • jackSparrowzx3
                        • Jan 2025
                        • 1
                        • Philippines
                        #33
                        Thanks smdflea your the best I fix my motherboard corrupt bios
                        • Um486sx
                          • Jun 2021
                          • 2
                          • Ukraine
                          #34
                          thanx
                          • Ahari
                            by Ahari
                            I...
                            08-13-2025, 06:12 AM
                          • mkdj
                            ASUS ZenBook UX480F : need help with cleaning the ME region of my BIOS dump
                            by mkdj
                            Dear all,
                            I have a ASUS ZenBook UX480F with the following symptoms:
                            I suspect it is a BIOS issue. So I decided to try to clean the ME region. I followed the guide on win-raid, and I believe I have done everything correctly. My problem is: when I open the outimage.bin in ME Analyzer, it says that it is Extracted, and not Region, Extracted as it should be. Is it normal, or did I do something not correctly? This is my first experience editing BIOS files.
                            I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...
                            10-19-2025, 04:41 AM
                          • Habble7
                            I need a BIOS dump for the Samsung S49CG934SU monitor
                            by Habble7
                            The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                            Suspected Cause:
                            I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                            Troubleshooting Attempts:
                            05-22-2025, 07:28 AM
                          • haitham sharabati
                            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                            by haitham sharabati
                            Hello engineers 😀,
                            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                            🔧 Device Info:
                            - Model: HP 15-da2007ne
                            - Product Number: 8XF55EA#ABV
                            - Serial Number: CND0338P0D
                            - CPU: Intel Celeron N4000
                            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                            💀 Problem:😅
                            - Device shows “Administrator Password”...
                            08-07-2025, 04:54 AM
                          • Citymin
                            NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                            by Citymin
                            My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                            The charging red LED lights up, but the charging screen doesn't show any indication.
                            When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                            (I've tried removing the battery and resetting the device, but the issue persists.)
                            NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                            PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                            S/N : 5RNK9FFT70...
                            08-05-2025, 05:12 AM
