Asus P2520L main board P552LA
  • bakre
    • Dec 2014
    • 105
    • Zwolle
    Hello gays i am looking for this schematics for
    Asus P2520L
    main board P552LA rev : 2.1
    if any one have it please upload it
    and thanks
  • cacla
    • Apr 2015
    • 442
    Re: Asus P2520L main board P552LA
    try this one
    • bakre
      • Dec 2014
      • 105
      • Zwolle
      thank for your help cacla
      if you have the full schematic it will be great
      the laptop was off i change the i/o ic now it is work on charger but on the battery it going on 5 second and going off again i check the supply of the battery it is going in the circuit
      when i connect the battery just the 3val present but when i connect the charger the 3val and 5 val present and it is work
      thanks a lot again
      • bakre
        • Dec 2014
        • 105
        • Zwolle
        i was testing the ic 1285a with adapter is giving 3 val and 5 val
        but on battrey it just give 3 val
        • cacla
          • Apr 2015
          • 442
          this is all i have man i am sorry
          • meritosari
            • Oct 2010
            • 774
            • Indonesia
            Mostly voltage rails if in battery mode doesn't have VALW (voltage always). Only need supply for EC, after that EC give command to activated all VALW, at same time to all voltage and signal required to power on all systems. That will reduce to using source power when only on Battery mode.
            Pics taken from compal's schematic, Most all laptop design have same frame work. Only for saving power.
            Sometime we should read other schematic for full understand "How circuit work". As usual schematic for asus hard to find.
            Did you check with known good battery? Probably the battery was defect
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              Of course its depend design from vendor the Mobo.
              Found the boardview:
              • bakre
                • Dec 2014
                • 105
                • Zwolle
                thanks gays for helping
                i have change the ic 3v 5v and it steel the same i feel it is a save battery mode
                when i connect the charger and i turn the laptop on it is work and when i disconnect the charger it remain on and it change to battery power but when i turn it off from windows and i need to go on again it not work an tell i connect the charger again
                • meritosari
                  • Oct 2010
                  • 774
                  • Indonesia
                  How about the charging proccess?
                  Make full charged the battery first, then start to troubleshoot only from battery.
                  When you pressing power button, do you get signal enable from EC to pin 6 of TPS51235.
                  • bakre
                    • Dec 2014
                    • 105
                    • Zwolle
                    thanks for reply meritosari
                    the EN sign is arrive to pin number 6 to the ic power
                    and it give the 5v 3v but after 10 seconds the main board it going off again
                    • mitjats
                      • Sep 2017
                      • 5
                      • Italy
                      Asus P2520L
                      and thanks
                      Follow it.
                      I have similar problem. Mine is completely dead. The only thing I see is that the L4434 chip (the one on page 5 of the pdf signed as #17 PSL8103) goes very hot as soon I attach the power cord, but without the schematics is very difficult to understand whats going on.
                      • dmartins
                        David M
                        • Apr 2014
                        • 197
                        • Lisbon
                        Hello , i know thats not my thread but i wanna know the reference of my mosfets that i attached
                        I received this board in poor condition and without the mosfets in question ...
                        • boyebaran
                          • Sep 2015
                          • 247
                          • iran
                          hi
                          file is damage .
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            File is ok, use 7zip or PeaZip to extract.
                            • ourlissene
                              • Jan 2021
                              • 3
                              • France
                              Originally posted by cacla
                              try this one
                              thank you
                              • AL._.EX
                                • Dec 2022
                                • 868
                                • Belarus
                                Schematic
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
                                • ygorsan
                                  LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                                  by ygorsan
                                  Hi everyone,
                                  I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                                  🧩 Problem Summary:
                                  • The TV keeps scrolling through the menu or selecting items by itself.
                                  • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                                  • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                                  • I
                                  07-28-2025, 08:34 AM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
                                • JDC
                                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                  by JDC
                                  ONN 100012588
                                  Issue: No Power, Then Rebooting After Main Board Change
                                  Short answer: replace main board and power board
                                  Technical answer: replace main board and Q306 & Q307 on power board.
                                  Long answer:
                                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                  07-15-2022, 07:39 AM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
