Insignia NS-L37Q-10A No Picture No Sound
  • jreb10
    • Jul 2011
    • 12
    This set was purchased in April 2009. Currently it appears to power up to some level, as the LED goes from red to blue as it should. There is no picture or sound from my satellite input or my antenna input.
    In the dark I can see a faint backlight, but there is no trace of any image on the screen.
    I did remove the back and look over the boards. All the capacitors seem to be rated for 105C. None look bad to my eye, nor can I see any component that appears suspect. Board pictures I have taken so far appear below.
    I'm not sure how to proceed. I am guessing that I want to test the power board outputs, but I'm not sure exactly how so I am asking for advice. I can handle a multimeter. Thanks in advance for any suggestions.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Insignia NS-L37Q-10A No Picture No Sound
    You, sir are a genius. That touch of the final picture showing the pinout of CN902 is a very nice touch.
    This is a slightly unusual power supply, but shouldn't present any difficulties. With AC power connected, but the TV off, check the voltages on CN902. You should be able to make contact through the top of the female connector. Use any of the GND pins for the black probe. In cases where two pins are labeled the same (ie, +5V), it isn't necessary to measure both. I would expect you would see voltages only on +5V and possibly PS_ON. Now turn the TV on and repeat. You should see voltages on all non-Gnd pins.
    If these check out, it will be time to check the main board - I see several LDO regulators that should be checked.
    PlainBill
    • jreb10
      • Jul 2011
      • 12
      AThank you for your complimentary response. I try.
      Here are the voltage readings from CN902:
      Pin Plugged In Powered Up
      O/F 0 3.27
      DIM 0 3.31
      +12 0 12.27
      +12 0 12.27
      GND 0 0
      GND 0 0
      GND 0 0
      +24 0 24.8
      +24 0 24.8
      PS_ON .10 4.69
      +5 5.17 5.15
      +5 5.17 5.15
      Her are a couple more photos of the main board.
      • PlainBill
        • Feb 2009
        • 7034
        O/F 0 3.27
        DIM 0 3.31
        +12 0 12.27
        +12 0 12.27
        GND 0 0
        GND 0 0
        GND 0 0
        +24 0 24.8
        +24 0 24.8
        PS_ON .10 4.69
        +5 5.17 5.15
        +5 5.17 5.15
        Those numbers indicate a power supply that is working properly.
        On the attached picture the orange circles indicate LDO regulators. What are the part numbers of these? Also, the pins are numbered (pin 2 is the tab), With power on, measure the voltage on each pin, and report it. I believe pin 1 is the input, pin 3 is the output, and the tab is ground.
        The yellow circles indicate bucking regulators. What is the part number of the 8 pin ic?
        PlainBill
        • jreb10
          • Jul 2011
          • 12
          Thank very much for your guidance.
          The two bucking regulators have the same part number on the 8 pin IC, as follows:
          SC4524B
          0841
          V34527
          The LDO regulators have different part numbers. The "northern" one is:
          L013
          G1084-33
          When I power up and do a voltage check, with the power supply GND as reference, I get the following:
          Pin 1: 0
          Pin 3: 5.11
          Tab: 3.22
          Here is the info for the "southern" one:
          1084
          -18PE
          995H8R
          Pin 1: 0
          Pin 3: 3.27
          Tab: 1.78
            Some more things to check:
            Confirm the part numbers of the 8-10 pin ICs circled in black.
            Also, test the diodes circled in red. To test: Turn TV off. Set your meter to diode mode. (If it doesn't have a diode mode, set it to the 2kohm range.) Place one black lead on one terminal and red lead on other terminal. Record reading. Reverse the leads; record the reading.
            If the diode is good, you should get around 200 - 800 one way, and infinity the other way.
            • PlainBill
              • Feb 2009
              • 7034
              SC4524B
              0841
              V34527
              L013
              G1084-33
              Pin 1: 0
              Pin 3: 5.11
              Tab: 3.22
              1084
              -18PE
              995H8R
              Pin 1: 0
              Pin 3: 3.27
              Tab: 1.78
              There are four LDO regulators. Are these the readings of the two between the tuner and the edge of the board, or the two closer to the middle of the board?
              Also, it's obvious I was wrong about the pinout.
              PlainBill
              • jreb10
                • Jul 2011
                • 12
                To PlainBill,
                Sorry for the oversight on my part. I fixated on the two near the middle of the board, and gave you those readings.
                For the two near the edge of the board:
                North One
                K431
                G9084
                Pin 1: 6.94
                Pin 3: 12.27
                Tab: 8.17
                South One
                AZ1117D
                -5.OE1
                9902K77
                Pin 1: 0
                Pin 3: 8.17
                Tab: 4.95
                • jreb10
                  • Jul 2011
                  • 12
                  For tom66:
                  Thank you for helping me.
                  The "north" IC number is:
                  4449
                  BA811A
                  The "south" IC number is:
                  194B
                  0838
                  Z963
                  I tested the diodes with the diode setting on the multimeter. Both the diodes have the same numbers on them, as follows:
                  0695
                  SM340A
                  "North" diode readings: .098/.089
                  "South" diode readings: .039/.051
                  These don't look too good to me.
                  • jreb10
                    • Jul 2011
                    • 12
                    I worked up the courage to unscrew the main board and flip it over for inspection. I found what looks like a solder bridge.
                    This lies underneath the large heat sink in the other photo.
                    Should I conclude that I am in the market for a new main board?
                      For tom66:
                      4449
                      BA811A
                      194B
                      0838
                      Z963
                      0695
                      SM340A
                      South IC datasheet:
                      No idea on the North IC. Are you sure on that part number?
                      Those diodes might still be good, but the circuit is interfering with them. Unfortunately, you'll have to lift one leg to measure them, and this is tricky.
                      A simpler approach. Measure the voltages across all the highlighted components while TV is on. For the big electrolytic capacitors, you may have to do it with the main board flipped over. Place red on one side, black on other. Don't worry about polarity.
                      • jreb10
                        • Jul 2011
                        • 12
                        Thanks for the reply tom66.
                        I am sure of the number on the north IC, in fact it was the easier of the two to read.
                        I see 4 components that you squared in red. I hope I did not miss any others.
                        For the capacitors, the big one on the left measured 24.5, the one on the right measured 5.1.
                        For the two remaining components, the one on the left measured 5.12, the one on the right measured 3.27.
                        Last edited by jreb10; 10-10-2011, 09:07 AM. Reason: Additional information added.
                          Yep only 4, those voltages seem okay.
                          I was using MS Paint on an office computer - and couldn't figure out how to make the boxes bigger.
                          At the very least, the 10pin converter is okay, and the 8pin one *probably* is.
                          Is there any chance of you getting the cover off the shield on the main board. There's probably a processor under there.
                          • jreb10
                            • Jul 2011
                            • 12
                            I took the cover off on the main board. Here are a couple of photos.
                            • ryghigh
                              • Dec 2011
                              • 1
                              Did you get this resolved? I'm having the same issue.
                              Thanks,
                              Ryan
                              • jose6326
                                Insignia Ns-l22x-10a no picture only sound
                                by jose6326
                                When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
                                When i was removing the back cover i heard a rattle.
                                Removed the metal plate and the heat sink was off (see pic)
                                would this cause a no picture/image issue?
                                What is used to put back the heat sink
                                07-30-2024, 11:03 PM
                              • TR103
                                by TR103
                                - it keeps rebooting
                                01-22-2025, 04:12 PM
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • Ierwin
                                by Ierwin
                                05-13-2025, 03:31 PM
                              • jchang
                                Samsung UN70NU6900F no picture and no sound
                                by jchang
                                Hi all
                                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                Symptom:
                                No picture no sound.
                                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                No sound at all.
                                What I tried:
                                1. I tried unplugging the left or right ribbon...
                                01-09-2023, 06:28 PM
