MS-7548 Failed TK Caps
  • mazade
    Jack of Trades
    • Apr 2010
    • 40
    Hello All,
    I just wanted to toss out a board that I haven't seen yet on badcaps, but have seen sold as "refurbished" on ebay(I wonder why).
    MS-7548 out of an HP AMD setup.
    The good caps on the board are Panasonic's as best I can tell.. [M]
    I'm seriously considering swapping the caps around the CPU to something like the UCC Poly 2.5v/820uf that's sold here. I've done some reading and I'm thinking that I ought to check to see how many of those particular ones are in parallel just to remove some of the mysteries of 'which is which', and 'do I use 2.5v, or higher'...
    As for the rest of the junker TK's, I've got some Samxon 6.3v/1800uf caps(courtesy of Badcaps.net )
    Oh geez, just noticed those smaller G-Luxon's too... should I worry about those? ...or was that a trick question?
    Last edited by mazade; 05-18-2011, 08:09 PM. Reason: spotted the smaller g-luxon caps
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: MS-7548 Failed TK Caps
    The 820uF will work fine for the Vcore caps.
    Just check CPU Vcore voltage in a data sheet. No need to break out a meter.
    Use a DMM to find out for sure if that odd one off to the side is Vcore or not.
    I replace G-Luxon if they are 6mm or larger, or 85C.
    You seem to know what your doing.
    Mann-Made Global Warming.
    - Dr Seuss
    • c_hegge
      • Sep 2009
      • 5219
      I see TK vented on ECS motherboards A LOT. I'm sure it stands for Terrible Kapacitor
      • Pyr0Beast
        • Feb 2009
        • 406
        Socket AM2. Working voltage should be under 1.5V
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          they choose to use pannys and solids on other parts of the board, but use cheap shit on the vrm, where better quality is needed. that board looks like it was designed to die
          • Pyr0Beast
            • Feb 2009
            • 406
            Not designed to die, to be _cost efficient_ )
            • mazade
              Jack of Trades
              • Apr 2010
              • 40
              So I looked a little more into the CRAPS surrounding the cpu and found that there's two groups, as seen in the picture.
              I suppose I can assume the group of greater quantity is the VCore voltages that I can/should Poly.
              What are the 3 stragglers(only two of those spots had caps in them), and what should I put in there??
              Thank you all very much for the contributions.
              • Pyr0Beast
                • Feb 2009
                • 406
                One is for Vcore, the other one for Vtt (termination voltage) (I think)
                A single cap would I think work, but there isn't any objection as to fill other places as well.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Do not lower voltage on caps when you don't know what the circuit voltage is.
                  - For the Vcore caps you know by the CPU specs.
                  Any others you have to check, usually with a DMM but you could bust out a pencil and paper and work out the schematic to figure it out if you REALLY wanted too.
                  And yes, the row of 8 are the Vcore caps.
                  - Dr Seuss
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    What is up with the missing MOSFET?
                    - Dr Seuss
                    • mazade
                      Jack of Trades
                      • Apr 2010
                      • 40
                      The Mosfet... that is very weird, I did not do that.
                      It looks as though one should be there, should I try to find one to replace it?
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        I asked about it because it kind'a looks like someone removed it.
                        See if you can find photos of the board on-line and see if that board has one there.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Looks like it was never there.
                          http://www.dhgate.com/msi-ms-7548-am...039005cf5.html
                          http://www.amdzone.com/phpbb3/viewto...?f=38&t=138381
                          http://www.serversupply.com/MSI/MOTH...8E/MS-7548.htm
                          - Dr Seuss
                          • mazade
                            Jack of Trades
                            • Apr 2010
                            • 40
                            Wow, what a sleuth. PCBONEZ, thanks for the helps.
                            • mazade
                              Jack of Trades
                              • Apr 2010
                              • 40
                              Well, although I took a few days to order the poly caps, I got them in today and 'slapped' them into place.
                              The previous, failed, setup was lacking a capacitor in that left-end spot, so I'm assuming that these superior caps can allow for it to remain empty.
                              All I need now is to get some ram and a cpu to test this puppy out with - ebay here I come!!! ^_^
                              • mazade
                                Jack of Trades
                                • Apr 2010
                                • 40
                                Well, typing on the recapped MS-7548 board.
                                Managed to get an X2 6000+ processor & failed-cap board from a guy on ebay... borrowed a 1GB
                                stick of ram from a friend and this Puppy(booted a live-CD of puppy linux) is moving right along.
                                Temperature hovers between 29C and 31C... I performed some of HardInfo's benchmarks a few times, the CPU temp momentarily touched on 34C
                                Things seem great so far.
                                Thanks for all the helps & tips!
                                Thanks for supplying the caps needed to fix another BadCaps board! ^_^
                                Til next time - bye for now.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Congrats!
                                  It works now and it even looks purdier too!
                                  - Dr Seuss
                                  • c_hegge
                                    • Sep 2009
                                    • 5219
                                    nice job with the poly mod
                                    • Peacemaker45
                                      • May 2012
                                      • 3
                                      Hello All,
                                      I have an MS-7548 with the same bank of failed TK caps as Mazade, so no need to post new pics.
                                      I am going to attempt the repair myself. I consider myself competent in electronics repair, a hobbyist if you will.
                                      The power supply voltages check out with a DMM but I am going to O-scope it to check for excessive ripple.
                                      A few questions before I get started:
                                      1. What caps should be used? (cost vs. practicality, the thing is 5 yrs old)
                                      2. How many? (I noticed that mazade used 1 more than OEM)
                                      3. Should my CPU be okay? (My wife first noticed it freezing up a couple months ago but now it doesnt even POST)
                                      • c_hegge
                                        • Sep 2009
                                        • 5219
                                        1. If you want to keep the cost down, then there's probably no need to poly-mod it. Use https://www.badcaps.net/store/produc...roducts_id=152 . they are good electrolytics and should be fine for the usefull life of the PC.
                                        2. If you're not modding anything, then just use the nine that were originally there. I think that there might be two similar caps between the DIMM slots and floppy connector. Replace them too.
                                        3. The CPU is *probably* fine. It just may not like getting an unstable voltage.
                                          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                                          by momaka
                                          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                                          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                                          https://www.badcaps.net/filedata/fetch?id=3591771
                                          https://www.badcaps.net/filedata/fetch?id=3591772
                                          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                                          https://www.badcaps.net/filedata/fetch?id=359177...
                                          03-12-2025, 03:42 PM
                                        • eryjus
                                          Heathkit IO-4205 Power Supply Caps
                                          by eryjus
                                          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                                          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                                          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          Identifying caps on an old Zoom 9000
                                          by Paxman_Swede
                                          Hello!
                                          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                                          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                                          I have studied the board and...
                                          01-14-2025, 09:51 AM
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          Hi everyone,
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
