Replace PicoFuse with 20mm quickblow
  • Qwertyco
    • Apr 2009
    • 18
    I can't locate a 240v 2a PicoFuse locally, can I replace it safely with a Maplins 20mm fuse holder and a glass 2a quickblow fuse?
    Why are PicoFuses used in the firt place?
    are they special, or just cheap?
    "Life is like a Dancing Monkey - Pretty amusing, until it starts to lob faeces at you"
  • PlainBill
    • Feb 2009
    • 7034
    Re: Replace PicoFuse with 20mm quickblow
    If force to substitute, I prefer to use a pigtail fuse. Using a fuse holder and fuse is also acceptable.
    A picofuse is used because it is small and easy to use in an automated assembly process. You want something to interrupt the circuit so a shorted transistor doesn't start a fire. Monitors aren't considered a user serviceable item, so a fuse holder isn't called for.
    PlainBill
    • Qwertyco
      • Apr 2009
      • 18
      PlainBill
      Cheers Bill, that opens up a few options for me.
      a pack of 10 maplins fuses and a bit of soldering will get me away!
      Of course, I'll probably have to find out why it blew in the first place!
      • PlainBill
        • Feb 2009
        • 7034
        Yes. And finding the responsible component by replacing the fuse with a length of 14 Ga wire is not a particularly safe way to do it!
        PlainBill
        • Qwertyco
          • Apr 2009
          • 18
          PlainBill
          If I did that, the component at fault would be the one that was burning - EASY!
          Meanwhile, back on earth . . . . . I pigtailed a 1.6a fuse in place of the pico, pluged in, switched on, got a quick flash of backlights before the fuse blew again.
          This is a Feb 2007 EMPREX LM-1905 19" Widescreen, Model No. LW1922c.
          Where do I go from Here?
          All I've fixed so far is 3 monitors with BadCaps, all with the help and inspiration from you guys!
          I have a multimeter, a soldering iron, and the internet!
          Do I need anything else?
          Cheers,
          Mike Q
          • PlainBill
            • Feb 2009
            • 7034
            Cheers,
            Mike Q
            Well, a digital camera, a good lighted magnifier, an ESR meter, and a ring tester (in that order) should be on the list.
            On the Emprex, you're looking at a problem in the inverter section. Odds are a driver has shorted. What I recommend in this case is taking good pictures of bothe top and bottom of the power supply / inverter. Attach them to your next post, and someone should be able to identify the drivers. Then it's up to you to check them. Sometimes it is easy - it's the component with a hole blown in it.
            PlainBill
            • Bobdee
              • Jun 2008
              • 461
              Cheers,
              Mike Q
              This may help for after you find fault
              http://cgi.ebay.co.uk/10-x-Axial-lea...item3ef7bcdf51
              BTW 125V will do it
              Bob
              • Qwertyco
                • Apr 2009
                • 18
                PlainBill
                I don't have an ESR or a Ring tester.
                No sign of any damage or scorch marks on any components!
                I'll have another good look this weekend.
                I have found that scanning things like this sometimes produces better pictures than a camera!
                I'll get some picofuses bought, thanks Bob.
                • Acnologia
                  Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
                  by Acnologia
                  Here is a pretty crazy one.
                  Step 1.
                  Laptop was brought to me as dead not working. Removed everything , cleared everything.
                  Step 2.
                  Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
                  Step 3.
                  Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
                  Step 4.
                  Lets ,dive into the board. I see the edp cable on the...
                  05-07-2025, 07:16 AM
                • jshhh
                  Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                  by jshhh
                  Hi guys,
                  I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                  How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                  Anybody know how to remove this type of fuse?
                  (The fuse is toward the bottom of the image labeled F2)...
                  06-17-2025, 01:35 AM
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • drykid
                  Matsui 175S microwave fuse replacement
                  by drykid
                  I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                  Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                  12-21-2020, 01:15 PM
