Samsung LCD TV LN40B530P7N Distorted Color Picture
  • Glitcher
    • Mar 2013
    • 673
    • USa
    I have a 40" Samsung Model: LN40B530P7N
    The color of the picture seems extra contrasted or distorted like. It would actually look kind of normal only when cartoons are playing. It affects all the inputs.
    If I'm seeing it right, it seems to be getting worst from when I turn on the Tv from cold and leave it on for awhile. A thermal issue? Should I check the Tcon or the Mainboard first?
    Re: Samsung LCD TV LN40B530P7N Distorted Color Picture
    Select a source which shows the issue.
    Turn TV off, leave it in standby.
    Press, on remote, Mute, 1, 8, 2, Power in quick succession.
    TV turns on. Service menu appears.
    Browse the menu. Look for options marked LVDS format. If you need help, take a picture of the service menu. If you find an LVDS format option, change the value using the remote to one of the other values until the picture comes back normal.
    • Glitcher
      • Mar 2013
      • 673
      • USa
      Got to the service menu, I found an option "LVDS Format" There was only 2 settings for it, JEIDA and VESA. It is default set on JEIDA, but changing it to VESA seem to make it worse.
        OK, set it back to the original, then look under Panel Enter Key. What appears when you select that?
        • Glitcher
          • Mar 2013
          • 673
          • USa
          I just tried a factory reset but no luck.. Clicking on Panel Enter key, it just says panel enter key on the screen but I'm pressing the buttons and nothings happening after.
            Nothing happens when you press enter, or left/right?
            Any "Panel Option" available?
            See this video.
            https://www.youtube.com/watch?v=c-aXKCTiU6I
            • Glitcher
              • Mar 2013
              • 673
              • USa
              Yep, nothing happens pressing left/right, enter, buttons, etc. Heres a couple more options I found.
              The picture actually looks like its becoming negative. When I first turned it on I thought to my self that the problem wasn't that bad, but now its really obvious, so I think it has been getting worse.
                Go down to PANEL TYPE and try selecting it.
                There is a chance it is GAMMA IC problem.
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  Just tried selected it, and I can't do anything with it either.
                    Very strange, can you go into TEST PATTERN and see what each test pattern looks like?
                    • Glitcher
                      • Mar 2013
                      • 673
                      • USa
                      All the solid colors seem to be good (black blue red, etc) until the later colors.
                        Personally I still think main board but can you take a picture of the T-con? May have common AS15G IC on it which fails and can cause a similar fault.
                        • Glitcher
                          • Mar 2013
                          • 673
                          • USa
                          Here you go, The T-con does have a AS15-F chip. Trying to find my compressed air spray.
                            See the points marked VGMA1, VGMA2 ... VGMA20?
                            Use your DMM to measure each. Put your black probe on the chassis of the TV and red on each pad from 1 to 20. DC20V range. See what readings you get, post them here.
                            • Glitcher
                              • Mar 2013
                              • 673
                              • USa
                              Heres all the measurements I got from pads 1-20. (In volts)
                              1: 15.46
                              2: 15.17
                              3: 15.04
                              4: 12.82
                              5: 11.9
                              6: 10.82
                              7: 10.17
                              8: 9.86
                              9: 8.51
                              10: 8.35
                              11: 7.90
                              12: 7.09
                              13: 6.86
                              14: 7.33
                              15: 11.44
                              16: 9.29
                              17: 4.66
                              18: 3.59
                              19: 2.65
                              20: 0.61
                                Definitely bad then. The voltages should decrease or increase one way only. That spike around 14-17 is probably the cause of the fault. Replacing the IC or the T-con should fix the fault. I retract my original conclusion of main board; I've just seen so many main board solarised picture faults recently I went straight for that.
                                  Just noticed there are pads 21 and 22. Could you test those too (for future reference for others.)
                                  • Glitcher
                                    • Mar 2013
                                    • 673
                                    • USa
                                    Pads 21 and 22
                                    21: 0.50V
                                    22: 0.25V
                                    Been searching for the Tcon around but can't seem to find it anywhere. There's only one result for it on ebay but its about $110.
                                    Do you know a good source to purchase the IC?
                                      Thanks for those.
                                      What is the full part # on the AS15 chip?
                                      • Glitcher
                                        • Mar 2013
                                        • 673
                                        • USa
                                        As15-f
                                        0838cg
                                        b8601677
                                        • ChattFix
                                          Samsung UN55TU700DFXZA Distorted Picture
                                          by ChattFix
                                          I have a Samsung UN55TU700DFXZA with a distorted picture and I thought it was a bad panel. I had a similar board with one number off and still tried it to see what the issue could be. The picture came out clear with only missing blue hue I think. I found a replacement board for $30 but wanted to learn if this would be the main IC or possibly something else. I don't have service manual so looking to learn about these cheap sets....
                                          06-02-2024, 03:50 PM
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
