Asus X50gl keeps crashing with ACPI THERMAL ZONE event
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    *long story* !
    Good day folks. Today I'd like to open up a topic which I only mentioned a couple of times in some other threads but never actually got into as deep as I would've liked, so hopefully some of our wonderful members here who may be more familiar with laptops than I am can provide some tips. Please bare with me, as there's a lot to cover...
    So: my old Asus laptop which I've used for the past 10 years and I dearly love started acting up some time ago...sounds boring, but it's actually more complicated than you might think. A while back, it would randomly shut down whenever I was watching something on Youtube in Firefox - yes, it's pretty specific, which further adds to the issue..aand it did it again....and again...and again...I thought for sure it's a heat issue (which it might be), so I checked and triple checked my heatsink, paste, fan all that jazz, even went out of the way to order a second fan and heatsink, thinking perhaps the heatpipe lost some of its properties and no longer dissipates properly...never solved the issue. It delayed the crashes slightly but it would still do it nonetheless.
    I then began monitoring my temps more closely, so I grabbed HWMonitor and ran some Prime95...nothing too out of the ordinary to report here: around 40C on the CPU and 57C on the GPU when idle at an ambient temperature of 27C and 70C on both at full load for 5 minutes. It's worth noting that it never once crashed when I stress tested it - THAT's the main issue here: you'd think it's a heat issue, but I'm skeptical about that, as it only seems to happen with Firefox and Youtube, never under clearly heavier loads - not even a different online video platform, say Dailymotion, causes the issue...it's ALWAYS YT. To confirm, I started using Opera for the past weeks or so and it solved the problem - no crashes at all. I thought for sure it's some sort of bug and I'd have to live with Opera, which is not terrible, but it all turned to sh!t today when it crashed once again and inspired me to write about it. It was on YT too, of course >_> The log indeed returns an "ACPI Thermal Zone has been enumerated" event every time this happens (don't have one on hand right now since I cleared it), but it always reports some trip point of 90+C (converted from K) which is clearly impossible for it to reach even at full load...don't know where these numbers come from.
    RAM ? Tested that as well several times with no apparent issues. Of course RAM testing is not exhaustive and it could very well have issues despite managing to work enough that one time to pass MemTest.
    Getting down at hardware level, I couldn't find a schematic for the F5GL model, but I did find a boardview (ironic, since it's usually the other way around !). If you open it up in your favourite boardviewer and search for U5000 (a G780P11U) you'll see it's a temp sensor. Unfortunately with no schematics, I have no idea how it's all wired up exactly, although I did use the boardviewer to track down some of its pins in that general area, which ultimately leads to the Nvidia GPU/Northbridge on CPU_THRM_DA/DC pins (SDA/SCL maybe ?). I doubt U500 ITSELF is faulty, since the temperature readouts appear to function. Usually a bad temp sensor swings negative or is stuck...IMO...
    So many variables here I'm not even sure where to start: failing BGA on the Nvidia chip ? Software issue (did a clean reinstall on a separate HDD BTW) ? What other tests should I perform to at least pinpoint the cause ? It's mostly about the sentimental value of the device and about learning stuff rather than the material worth of this laptop in its current state, which is close to zilch at this point really....Cheers guys. Any idea or tip is welcome as always
    Wattevah...
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: Asus X50gl keeps crashing with ACPI THERMAL ZONE event
    from what i read in the intel datasheets, a thermal trip event can also be triggered if the vrm mosfets get too hot. now why the mosfets would suddenly get too hot when they werent running hot from before is not known and will have to be investigated by you. it could be due to bad caps, bad power supply/brick supplying unstable/noisy power, bad battery etc. among many other things.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Agreed - it can definitely be caused by a lot of factors...guess a cap replacement on the CPU "rail" (VRM as you call it ?) would be welcome but may not necessarily be THE fix...
      Wattevah...
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Looks like a shutdown because of bad cooling.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • piernov
          • Jan 2016
          • 4439
          • France
          Youtube will load both the CPU and the GPU at the same time.
          Also usually if you try to load both the GPU and CPU with a stress test it won't work, the CPU will get 100% usage and the GPU won't have enough CPU time so it won't be loaded enough. You could try stressing only one core of the CPU + the GPU.
          GPU seems like it could be from the defective NVidia series so that's not to exclude.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Right, forgot to mention I also tried FurMark to stress-test the GPU and the same thing happened: temps went up and stabilized but never actually crashed. Also, like most laptops, it uses an in-line heatpipe design, so some heat from the CPU will invariably go back to the CPU die and vice versa.
            Wattevah...
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3627
              • slovakia
              if u have good temps and stable everything, than just cut off that signal
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                I too thought of somehow disconnecting u5000, but I'm not sure it can be done just like that. I was hoping there'd be a 0 ohm resistor or some other component which I can remove, but there isn't one - the chip is hard-wired to the ITE (if I remember correctly), so I would have to cut its track and hope it still turns on at all. It might report some bogus temps and cause the system to shut down insantly...
                Wattevah...
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  try another power brick... other than that cold joint on some chip... strange things like that always caused by cold joints... either on voltage regulator chips on some of the bga...
                  Im Back... sort of...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    I considered the power brick at one point but quickly dismissed it on grounds that the battery is still functional so it should have switched over (?) and it never crashes when stress-testing, which might've indeed included the possibility of a bad brick.
                    Bad joints ? Could be after all these years. After all, 11 years is asking a LOT from a laptop...
                    Wattevah...
                    • piernov
                      Compaq SR1000 MSI MS-6577 ACPI fix
                      by piernov
                      Compaq Presario SR1000 / SR1116FR, MSI MS-6577 (Xenon) Gamila/Giovani/Neon series
                      ACPI fix!
                      Yes, you read that right, the bug that HP/Compaq never fixed is finally no more, 16 years later. You probably don't care but here it is anyway.
                      Bug
                      Basically the bug is as follow: you want to use Linux on this machine, but it doesn't power off when you shut it down, you cannot put it to sleep, nouveau driver for NVidia GPUs doesn't load, etc…
                      At boot, you may be greeted by the following message:
                      Code:
                        [ 0.000000] ACPI Error: A valid RSDP was
                      11-30-2021, 02:34 PM
                    • howardc64
                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                      by howardc64
                      Problem
                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                      Model & Board Pics
                      Conflicting Spec
                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                      https://www.shopjimmy.com/vizio-gj-2k1...
                      10-10-2024, 01:16 PM
                    • DeanWy
                      WD Sentinel DS5100 (NAS) boot issues
                      by DeanWy
                      I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                      It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                      There...
                      07-30-2024, 04:13 AM
                    • siccfix
                      HP Omen 15-ek0013dx - Odd 4-Zone RGB Issue, Replacing Entire Keydeck Didn't Fix It
                      by siccfix
                      Replaced the keyboard+LED backlight+topdeck unit with a completely assembled aftermarket part a few months ago due to failing keys (Spacebar, X, R; seems to be a common issue for 2020 model). I thought this would also fix my RGB backlight issue but the problem remains, actually it got worse, so it has to be a failing part on the mobo itself. The middle RGB zone can no longer light up blue and is instead stuck on green, even if all kb backlight is turned off that zone stays lit..
                      Does anyone know what part number the IC labeled UI3 is? Seems to be some kind of LED controller chip....
                      04-24-2025, 08:54 AM
                    • angel35
                      Fujitsu D3445-K11 Random BSOD ACPI BIOS ERROR in Windows 10
                      by angel35
                      An skylake (H110) Fujitsu PC mothardboard (D3445-K11) somethimes can't start...Appear BSOD ACPI BIOS ERROR in Windows 10
                      (like below picture)
                      What can cause somethimes ok, somethimes not good ACPI state? Really strange
                      If ACPI not good the Bios missing information from SMbus like FAN speed Voltages etc
                      Wong Bios IC? Power problem?
                      Wrong status:
                      Good status somethimes:
                      07-27-2024, 04:04 PM
