Image Issues with Dynex DX-L42-10A
  • somenights
    • Sep 2013
    • 11
    Alright, so I have a Dynex DX-L42-10A. It's been loyal and had no troubles throughout the few years we've been together. I moved about a week ago and two days ago after spending the time getting all my components and wires hooked up and organized I decided to watch a movie. About 25 minutes in, the screen starts flashing white every few seconds. I look down at my phone then look back up and the screen is almost completely white with a negative effect on the image you can see. The sound didn't change at all, just the picture.
    I tried doing a reset through the menu (which also presents as negative or whatever effect you would call this), no change.
    I did some searching online and decided to see what I could figure out on my own since I don't have the funds to purchase a new tv, plus if I can fix it I'd rather do that (save the money, solve the puzzle, woot).
    Soooooo any advice?? Where do I start? I've never tried to fix anything quite like this before, so I have no idea what I'm doing.
    Your help is much appreciated!
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Image Issues with Dynex DX-L42-10A
    Does it do it on the menu as well? Or just on the input.
    Have you opened it and looked for any visibly bulged capacitors, loose connections, or obviously burned components?
    • somenights
      • Sep 2013
      • 11
      Yes, it does do it on the menu as well.
      I did open it up about an hour ago and nothing looks obviously wrong. The connection points all look clean and intact, the capacitors all look fine. To me...
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Pictures would be great
        • somenights
          • Sep 2013
          • 11
          For some reason the website keeps telling me server error, but i did manage to get this one uploaded. I've got 3 more I'll keep trying, but here's this one of the image itself:
          • somenights
            • Sep 2013
            • 11
            The other three:
            https://sphotos-a-atl.xx.fbcdn.net/h...38181586_n.jpg
              Look at the top left SQ IC under the thermal pad to see if it is AIS15 Gamma ref voltage IC.
              • somenights
                • Sep 2013
                • 11
                I have no idea what that means :/
                  There is an IC on the top left of the board that may have P/N ASI15x printed on the top, you need to look, if it is, you need to replace the SMD IC or replace the T-CON board to fix the problem.
                  • somenights
                    • Sep 2013
                    • 11
                    Alright, so if I order a t-con board, what're the chances that this issue will resolve??
                    I just don't want to shuck out money for parts and end up not being able to fix it...
                      You are going to have to put in new T-CON board to find out, there is no 100% to verify the problem or you can take to the TV shop to get the 2nd opinion. So did you look at the IC number as request?
                      • DemonBG
                        • Mar 2012
                        • 143
                        Visually the board looks very similar to a Samsung i had a similar problem with myself:
                        https://www.badcaps.net/forum/showth...d=1#post351636
                        Part numbers are NOT the same but i would hazard a guess and say that the symptoms are almost exactly the same as mine - Which was had a faulty ASI15x Chip on the T-Con Board.
                        Take a look underneath the small square foam pad (to the top left of the picture) and see if it reads ASI15 or something similar. If so, then i would suggest replacing the T-Con board. Make sure you have a thermal pad (one of those foam looking pads) on the replacement board too or it will go bad very quickly!
                        Good luck,
                        Demon
                          That is what I have been trying to get him to do since post 9. I gave up.
                          • somenights
                            • Sep 2013
                            • 11
                            #1) I'm a her, not a him.
                            #2) demonBG was much clearer in directions, especially considering I've already said I have never done anything with electronics in the past before. If this were a car itd be fixed already, but I am out of my element here...
                            #3) I just started a new job and moved, so i literally spent the weekend unpacking and have been getting home and sleeping and then leaving again during the week, so I haven't had much of a chance to sit and fiddle with this tv.
                            Anyways...back to business.
                            I am not seeing "ASI15" but the board does look just like the image of yours, Demon. Your images also look just like mine did. It started fine, then took on the negative effect, then gets really white. Now it doesn't display correctly at all, just goes straight to the negative.
                            Does that seem similar to the way yours ended up? If so, I'm thinking I'll give the tcon board a go and hope for the best.
                            • Caleb
                              Smokin IC's
                              • Feb 2013
                              • 645
                              Can you post the board number? I cant seem to read all the numbers off the picture. I may have one in the parts pile from a 40" model with a broken screen.
                              Liberating magic smoke one part at a time
                              • somenights
                                • Sep 2013
                                • 11
                                Directly on the board it says:
                                T420HW02 VO
                                On the barcode it says:
                                TX-5542T04C06-921-DL60000-01699-03
                                • martino
                                  Not so "senior"
                                  • Aug 2013
                                  • 997
                                  • canada
                                  Lol at post#13,that cracked me up
                                  Proud owner of dozens of broken TV's and many,many,many boards.
                                  Our website and passion:http://hollenhundshepherds.com/
                                  • Caleb
                                    Smokin IC's
                                    • Feb 2013
                                    • 645
                                    I checked and the board I have is not a match, sorry. You should be able to locate one on shop jimmy or eBay
                                      https://www.badcaps.net/forum/showth...156#post374156 bad AS15 Gamma IC T-CON success repair, about $59 at Shopjimmy, not going to be funny at $59.
                                      • somenights
                                        • Sep 2013
                                        • 11
                                        Alright, I will order and keep you posted on how it goes. Thanks all for all your help.
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • Jaime Morillo
                                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                          by Jaime Morillo
                                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                          The TV was stuck on the logo and I couldn't access the update menu.
                                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                          The image result was good, but the image is inverted.
                                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                          08-18-2025, 11:38 AM
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 10:56 AM
                                          HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
