For a fair amount of time now, my board hasn't been the overclocker it used to be. Now that I'm upgrading to Athlon 64, I've decided to replace the major caps on this board out of general suspicion so I can keep using the board in the other rig. Today was the first time I've been able to get the board out of the case for a close inspection of the caps on it. Though I can't afford to buy caps at the moment, I thought I would list what it does have in the above 500uf range for anyone else who may have this board and Aopen's other nForce2 boards.
Lelon RXA 10v 10mm 3300uf x3
Samsung KZE 6.3v 10mm 2200uf x7
Samsung KZE 6.3v 10mm 1500uf x4
Samsung TMZ 6.3v 8mm 1000uf x3
Samsung KZE 16v 8mm 680uf x1
The Lelons on my board appear to be doing well. No outward signs of problems. Two of the Samsung 2200's, which surround the CPU socket, look to be bulging somewhat at the base however (was hard to tell - could be dust but probably not).
I plan to order it new caps in the next month or so if I can manage it, probably going with Panasonic FC for all of them. Replacing the Lelons may be a challenge - they're close together and the only FC's that even come close are 12mm. The other caps don't look to be a problem as far as diameter goes.
Would appreciate suggestions on alternative caps for the Lelons - I'm thinking of ordering the caps from this site as well if I can't find anything at Digikey.
Lelon
