MacBook air Model A1466 EMC 2925 820-00165-A
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    Model A1466
    EMC 2925
    MBA: 820-00165-A
    Hello guys,
    I attached my original dump,is locked, if someone can clean it
    thanks
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    Re: MacBook air Model A1466 EMC 2925 820-00165-A
    Help me clean it
    • teqcom
      • Nov 2015
      • 311
      • malasyia
      need clean this bios plz thx
      • teqcom
        • Nov 2015
        • 311
        • malasyia
        Hello guys i alrdy finde Clean ME file
        • ADEE
          • Nov 2015
          • 1
          • GR
          Cleaned
          • peste
            • Dec 2016
            • 13721
            • ROMANIA
            Originally posted by ADEE
            Cleaned
            try..
            • piszpunta
              • Jan 2019
              • 259
              • poland
              please clean ME REGION
              a1466
              820-00165-a emc 2925
              • peste
                • Dec 2016
                • 13721
                • ROMANIA
                a1466
                try..
                • osman68i
                  • May 2015
                  • 354
                  • The Netherlands
                  a1466
                  clean me
                  • piszpunta
                    • Jan 2019
                    • 259
                    • poland
                    Originally posted by peste
                    try..
                    not work.
                    on bios from another forum works. but there is an invalid serial number
                    • osman68i
                      • May 2015
                      • 354
                      • The Netherlands
                      not work.
                      with your snn
                      • piszpunta
                        • Jan 2019
                        • 259
                        • poland
                        Originally posted by osman68i
                        with your snn
                        can't see any disk
                        • osman68i
                          • May 2015
                          • 354
                          • The Netherlands
                          can't see any disk
                          because the firmware you have downloaded is old. not support apfs
                          • piszpunta
                            • Jan 2019
                            • 259
                            • poland
                            everything is fine on the bios from post 10, but my serial number is missing
                            • elsomer
                              • Jun 2012
                              • 50
                              • mexico
                              Hi, can someone help me with this dump that is locked when i try to install so, thanks
                              • peste
                                • Dec 2016
                                • 13721
                                • ROMANIA
                                try..
                                • bigig
                                  • Oct 2019
                                  • 12
                                  • st lucia
                                  a1466 emc 2925
                                  can someone please help me to remove efi lock
                                  • .::iRizwan::.
                                    Banned
                                    • Apr 2016
                                    • 63
                                    • Pakistan
                                    Originally posted by bigig
                                    a1466 emc 2925
                                    Here you go.
                                    Remember to PRAM reset afterwards.
                                    • bilen
                                      • Aug 2014
                                      • 637
                                      • istanbul
                                      A1466 bios problem
                                      The first screen comes late and unable to install
                                      Can you clean the bios or give a new bios?
                                      sn : C02QJ303G940
                                      EMC : 2925
                                      corrupt bios :
                                        • 22095
                                        Re: A1466 bios problem
                                        sn : C02QJ303G940
                                        EMC : 2925
                                        corrupt bios :
                                        Just use one of the ME cleaned bios in this thread.You will need to change the serial number,see this "4.3. Apple" https://www.badcaps.net/forum/showpo...43&postcount=5 ,watch piernov`s video.Also there`s some software you can use on github to change the serial and more , Apple_EFI-Patcher https://github.com/sadponyguerillaboy
                                        • yura8
                                          Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
                                          by yura8
                                          Hi there! I have not so usual situation...
                                          I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
                                          My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
                                          P.S. If you have else any ideas about repair, or you had a similar...
                                          12-20-2024, 02:31 PM
                                        • sofles
                                          Macbook a1707 2017 model 820-00928 GPU issue
                                          by sofles
                                          Hello there
                                          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                          11-21-2024, 05:25 AM
                                        • psdavid65
                                          Macbook Air A1466 820-3437-B Booting Problem
                                          by psdavid65
                                          I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
                                          06-20-2024, 12:27 AM
                                        • dbuergi
                                          Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
                                          by dbuergi
                                          i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
                                          Any ideas where to look?...
                                          11-07-2024, 10:57 AM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
