840 G1 , 840 G3 and 8470p bios passwords
  • frozen_neo
    • Oct 2015
    • 9
    • Portugal
    Hi Guys. I've bought a big lot of laptops (840 G1, 840 G3 and 8470p). My problem is that all of them came with a BIOS password. I´ve already done the reprogram in one of each and it's working fine, but i still have something like 100 Laptops to reprogram.....
    Do you know if there is a way of decrypt a bin dump file , by reading it with HxD or something like that, or if there is a easier way to do this? i've got a very short schedule and i'm afraid i cannot deliver the product to my client in time
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: 840 G1 , 840 G3 and 8470p
    I send you file or clue you can work all laptop this methods this 1 is easy i think
    i send you file search in hex this 1st hex data like this (24 56 53 53 B8) or find original lock just replace and done.
    Or without reading bios chip no have solution always read bios chip and then remove
    • frozen_neo
      • Oct 2015
      • 9
      • Portugal
      Thanks for your response imranromi. I already have one copy of each dump file of each laptop. This way i can program, but my issue here is that i need to do this for each one of them (take out, reprogram, put back in) times 100... By reading the bin file isn't it possible to check the password?
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        But 840 g1 or g40 g3 you copy bios give late display.
        No you always put and back step repeat no have other solution
        • RethoricalCheese
          • Mar 2013
          • 1518
          • Estonia
          Re: 840 G1 , 840 G3 and 8470p bios passwords
          Hey! I have sent you a tool via email that might speed things up for you. It is still in testing phase so I would like you to test and report back before I upload the tool in the forums.
          • frozen_neo
            • Oct 2015
            • 9
            • Portugal
            RethoricalCheese Thank you so much for your reply. It might be a good solutions in case i dont find a dump file,and i will keep it to test in a different model someday in the future. In this case i would really need the password. All the laptops i've got have the same password, so the idea here was to try to decrypt the file somehow.
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              Hp laptop cannot find the password the file hp RSA file.Lenovo some model find the password..
              • imranromi
                • Jan 2015
                • 1288
                • Pakistan
                Hello friend i want to check tool i have lock laptop different model
                If you send my email:********************* i wait thanks
                • RethoricalCheese
                  • Mar 2013
                  • 1518
                  • Estonia
                  Will post it soon.
                  Anyway, on the topic. A quick search found this: https://www.serializing.me/2016/10/1...ds-decryption/
                  Maybe it can be used somehow to decrypt passwords stored in bios.
                  I don't have an HP at home right now so I can't test with known passwords.
                  If it really works then I think it is possible to make a windows/dos program which retrieves and decrypts the password and eithers just shows it or maybe sends that data to an arduino and after restarting and pushing a button on arduino it writes that same password in bios password prompt and does the rest of the unlocking automatically. Atleast that's what I would try to make
                  • frozen_neo
                    • Oct 2015
                    • 9
                    • Portugal
                    Will post it soon.
                    Yeah it does work, but not directly. The password has to be created by the HP software and the dump file that it creates afterwards can be decrypted. The BIOS one although is a little different. By finding the code in BIOS where the password is stored it might work i hope.... but i didn't find it yet
                    Anyway, if someone wants the code already compiled, i leave here the file
                    • fyaagoub
                      • Dec 2016
                      • 269
                      • maroc
                      HELLO TRY THIS
                      https://github.com/texhex/BiosSledgehammer
                      • RethoricalCheese
                        • Mar 2013
                        • 1518
                        • Estonia
                        Well, I guess the password in bios is stored after BIOSAdminScanCode between 00 00 00 and aa 55. But that decrypt tool wasn't able to decrypt that.
                        • frozen_neo
                          • Oct 2015
                          • 9
                          • Portugal
                          Originally posted by fyaagoub
                          This is the kind of solution i'm looking for.
                          The last day i've been trying to use it. I even made a Batch file to create passwords in Bin format individualy with the HPQPSWD tool. I'm still trying to find a way to force the reading with this program. Tried in a laptop with a password that i know of (EX:11112222) and when the program reads the bin file with that same password, it gives me an 666 error, which means is not reaching the BIOS. Anyone tryed already this with sucess?
                          • frozen_neo
                            • Oct 2015
                            • 9
                            • Portugal
                            Ok, i manage to create a batch file which uses both HPQPswd and BiosConfigUtility from HP and after some thinking, it started accessing th BIOS. The program uses combinations and try to bruteforce it. the only problem is it's way too slow. It tests something like 62 words a minute... anyone knows a way of opening the BiosConfigUtility faster? i can leave what i have done here if you want to check
                            • frozen_neo
                              • Oct 2015
                              • 9
                              • Portugal
                              Anyone can help me with this issue? still looking for solutions....
                              • biospwd
                                Banned
                                • Oct 2019
                                • 51
                                • Ireland
                                Send here bios dump then i unlock.
                                • RethoricalCheese
                                  • Mar 2013
                                  • 1518
                                  • Estonia
                                  He doesn't want unlocking, he wants to find out what the password is.
                                  • biospwd
                                    Banned
                                    • Oct 2019
                                    • 51
                                    • Ireland
                                    @frozen_neo send 100-200 dump. I unlock all fast by soft.
                                    HP password are in bios in different place.
                                    U can search in dump words like: Admin, passphrase etc. but you will lose a lot of time editing.
                                    So if u have XXX laptop , the best way will be to do bios backup and upload here then i unlock all.
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1518
                                      • Estonia
                                      Well, he already has my software to unlock them but because all the laptops have same password, it could be much faster to find out the password instead of unlocking using dump. Read the topic from the beginning.
                                      • EineWildeStehlampe
                                        • Jun 2021
                                        • 13
                                        I know this thread is somewhat old but I've been experimenting with those HP laptops with the HP_BIOSAdminScancode structure a bit today and found out that it is in fact quite easy to brute force them given a certain maximum character length.
                                        The encrption mechanism works like this:
                                        The entered password is firstly stored as a Scancode string (see https://www.scs.stanford.edu/10wi-cs...s-1.html#ss1.4 for example), so "q" becomes 0x10, "w" becomes "0x11", etc.
                                        That hex string of scancodes is then simply hashed with SHA1.
                                        So to decrypt them we can just use something like Hashcat running on a GPU. For example for a password of maximum 8 characters length only using letters and numbers we can use:
                                        "hashcat -m 100 -a 3 --hex-charset --increment -1 101112131415161718191e1f202122232425262c2d2e2f30313202030405060708090a0b sha1.txt ?1?1?1?1?1?1?1?1"
                                        where "sha1.txt" simply contains the SHA1 value we can extract from the "HP_BIOSAdminScancode" NVRAM variable body. The resulting string will be in Scancode format and has to be converted back, again using the Scancode table.
                                        I tried this with a few HP images I found on the web and luckily most of them were less than 8 characters, only containing letters and numbers so I was able to test this a few times.
                                        • Citymin
                                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                          by Citymin
                                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                          The charging red LED lights up, but the charging screen doesn't show any indication.
                                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                          (I've tried removing the battery and resetting the device, but the issue persists.)
                                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • Forest79
                                          Lenovo ThinkStation P520 BIOS file needed
                                          by Forest79
                                          I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
                                          The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • Fr33man
                                          BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
                                          by Fr33man
                                          I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
                                          *Novo button power on
                                          *Disconnected internal battery...
                                          09-23-2024, 01:16 PM
