Acer aspire 7520 power problem
  • primoz1
    • Oct 2010
    • 270
    • Italy-Slovenia
    Hi again. I got this laptop with integrated nvidia graphic on board, I reball GPU about month or two back ago, and then work OK. Now has a problem, work if has battery and AC power is connected, but just first time if I shut down laptop and try switched on again (with power button) then not react at all, but if pull out AC connector and put back, then work again, if I try started without battery and AC power connected, no react again.
    Laptop (when started) works OK.
    What colud be wrong ? AC adapter is OK, even I try with another adapter who is 100% OK. but no changes.
  • xaviero1412
    • Apr 2009
    • 56
    Re: Acer aspire 7520 power problem
    try update bios first...
    • primoz1
      • Oct 2010
      • 270
      • Italy-Slovenia
      Hi. I update bios from windows, and no changes. Once try start without battery in this way, unplug power and remove battery and hold power button app. 60 sec, then with pushed power button, connect power plug, release and push again power button and laptop started, but when I try again no work. So this laptop only start with battery, after start can plug power and work normal.
      • xaviero1412
        • Apr 2009
        • 56
        it just probably guests,
        1. check vccore
        2. check vdisp
        i think that 2 voltages are priority to check first after doing update bios and no any progress
        • primoz1
          • Oct 2010
          • 270
          • Italy-Slovenia
          1. check vccore
          2. check vdisp
          Hi what do you mean with this vccore and vdisp ?
          • xaviero1412
            • Apr 2009
            • 56
            vccore is cpu core voltage
            vdisp is display/VGA voltage
            • primoz1
              • Oct 2010
              • 270
              • Italy-Slovenia
              Aha, how can I do this test ? With some software or multimeter ?
              • xaviero1412
                • Apr 2009
                • 56
                at this state, u cant check via s/w.
                u must check with multimeter voltage reading through hardware.
                • primoz1
                  • Oct 2010
                  • 270
                  • Italy-Slovenia
                  Ok. But how can I do this, because Im not familiar with multimeter ?
                  Thankyou.
                  • xaviero1412
                    • Apr 2009
                    • 56
                    sorry , i cant tell you any further since u not familiar with metering-job... i'm afraid u will damaging ur precious laptop....
                    please, take some any basic electro class or u can search n learn online... utube n google is your friend...
                    • primoz1
                      • Oct 2010
                      • 270
                      • Italy-Slovenia
                      Hi. I can use multimeter, but I don know what on motherboard must check, with that part I do not have much experience, that I try to say.
                      • xaviero1412
                        • Apr 2009
                        • 56
                        check power coil (PL) voltage near the processor and southbridge or VGA
                        • primoz1
                          • Oct 2010
                          • 270
                          • Italy-Slovenia
                          Hi I hope Im measure correct elements (cube coils)
                          I must say first I try ohm conductivity for each coil , then I connect battery and power plug and turn on motherboard, and check voltage of coils, black wire tester I put on minus like on pictures, and rapid lost voltage on this coils.
                          I try first with battery and then remowe battery and result is the same.
                          • xaviero1412
                            • Apr 2009
                            • 56
                            measure it with and with-out processor, and always write it down....
                            check voltage on red-pointer, especially the coil nearest processor.
                            it its lower than 1v, replace the blue-checklist with 2.5v 470uf caps.
                            the yellow-checklist will not be replace if the above 4caps 470uf has solve the problem
                            • primoz1
                              • Oct 2010
                              • 270
                              • Italy-Slovenia
                              Hi I check again without CPU and get this values.
                              I search this 470 uf capacitors.
                              • xaviero1412
                                • Apr 2009
                                • 56
                                so, positive 100% the problem is at cpu_core/vccore.... just replace the 4caps....
                                • 12ax7a
                                  • Oct 2009
                                  • 21
                                  your black dvm lead may be in the wrong hole for measuring ohms & voltage... although some voltages do seem legit.. that 10A hole is usually for current only. normally you'd use the COM hole for those measurements. too fuzzy to read the meter writing from here. just something to check.
                                  • primoz1
                                    • Oct 2010
                                    • 270
                                    • Italy-Slovenia
                                    Hi. I replaced all 4 capacotors. Now sometime start without battery just pliged on AC power, sometime not, if once start, then can turned ON and OFF with power switch, but just 5-6 times, then wont start again, but with battery start OK. If I found another 7520 board I will try change yellow element too, this 4 capacitors I grab from 5520g with damaged southbridge pins (puled out from board) but 5520g not have this yellow element.
                                    I will report what happend, thank's for help.
                                    • xaviero1412
                                      • Apr 2009
                                      • 56
                                      replace them with new capacitor, not from damage boards.
                                      • primoz1
                                        • Oct 2010
                                        • 270
                                        • Italy-Slovenia
                                        Hi thanks for all, I change two capacitor with new and now is all OK.
                                        But I got another acer aspire 5520 with graphic on card, but no show any picture, I try with another graphivc card and still no changes. So I measure coils on similar spots like on 7520 and get this voltages.
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          Acer Aspire Aspire One 532h Netbook One Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Aspire One 532h Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire One 532h boardview and Aspire One 532h schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                        • DenK
                                          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                                          by DenK
                                          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                                          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                                          12-06-2024, 01:29 AM
                                        • Bonaventure Vigil
                                          ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                                          by Bonaventure Vigil
                                          Dear All,
                                          Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                                          At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                                          12-12-2024, 10:22 AM
