Philips smart TV problems
  • Timh77
    • Sep 2019
    • 4
    TV is a Phillips 55" 4K smart TV model# 55pfl5402/f7. My kid was watching tv and went to switch over to firestick and when she hit source button TV shutoff then turned on and continued to turn on and off by itself. Unplugged it for awhile to to avail. I replaced the main board which fixed the turning on and off problem but know when TV is turned on there is no picture or sound. What do i go after next?
    Last edited by Timh77; 09-22-2019, 04:54 AM. Reason: Putting in model number of tv in the header line
  • Diah
    • Feb 2013
    • 6437
    Re: Philips smart TV problems
    i think it would be better to you and to us if we trouble shooting the Original ( turn on off ) main board instate the replacement one. so please upload very clear photo on the original boards from both side.. and especially notice if you can track 2 soldering points with SDM label
    • Timh77
      • Sep 2019
      • 4
      • Diah
        • Feb 2013
        • 6437
        i cant track the SDM joint point at yours photos. the reason i mentioned to trouble shooting the original main boards because Philips 4K TVs not all main boards based on same model for example for model 55pfl5402/f7 there 2 groups each used different firmware and drivers:
        1- TVs Serial number begins with DS1A or DS7A and DS4A passed together as they used same Firmware and drivers
        2-TVs Serial number begins with DS2A or DS9A or DSCA or DSBA or DSAA DS3A or DSDA or DSEA or DS5A and DSFA passed together but cant be used at first groups.
        my question with replacement MB when TV go on did you have the LED back light goes ON ?
        • Timh77
          • Sep 2019
          • 4
          Yes back light comes on. Just no picture or sound.
          • Diah
            • Feb 2013
            • 6437
            good. please right down here yours Philips serial no( located on the back cover and on the aluminum chassis ). and post clear photo on yours replacement MB.
            EDIT:
            you can also try this test. with replacement MB in place after turn on the set and it keep on. press on RC the power to put the set in Standby mode. keep it at STBY mode and just plug out the power cable from wall sockt.
            wait at least 10 minute then put back your Original MB. after this just plug back the wall socket. and check the set will remain at STBY mode.. report the result.
            • Diah
              • Feb 2013
              • 6437
              BTW i just noticed yours photo of OR MB are kidding??? who took out the PC socket from it and 2 others Caps .. forget my test i mentioned above..it may the story of this Philips wasn't 100% correct
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4461
                • Italy - Milan
                Diah what do you say? USb+RJ45 are in place, some caps are not mounted by factory..
                Tim: If i help you to fix your new board you agree to send me your old broken board? :-)))
                PS: only if the shipment cost is not too high...
                • nomoresonys
                  • 12276
                  • U.S.
                  Keep your boards Tim, you never know when you might need a spare part.
                  • Diah
                    • Feb 2013
                    • 6437
                    Originally posted by Davi.p
                    Diah what do you say? USb+RJ45 are in place, some caps are not mounted by factory...
                    PC RGB Input socket , till now i didn't saw Philips 4K or smart with out RGB IN, over the net too i couldn't find MB BA51RJG0401 2 with out this socket.
                    in firmware if there option at Source to switch to RGB and on MB no such hardware of sure the TV will be at boot loop.
                      Manual:
                      https://cdn.badcaps-static.com/pdfs/...10b51f0be2.pdf
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4461
                        • Italy - Milan
                        Diah i don't see traces of desoldering work and the VGA is not used on many newer models, since is a port that is less used than before..
                        If you feel that the story is not complete i agree with this doubt 'cause i've never heard of a tv that brokes by a button hit..
                        • Diah
                          • Feb 2013
                          • 6437
                          could some one explain this to me.. the manual mentioned by budm there are no such socket... but this is MB sold to the same model
                          Philips 55pfl5402/f7 Main Board Ba51rjg0401 2
                          https://www.ebay.com/p/7015735775
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4461
                            • Italy - Milan
                            You may want to watch for the revision, Philips could have decided to remove that in a second revision due to cost reducing..
                              Probably for the US market for this model, then the higher version of the same series may have it.
                              https://www.shopjimmy.com/catalogsea...55pfl5402%2Ff7
                              • Diah
                                • Feb 2013
                                • 6437
                                now its clear.. as i wrote at my POST #4 there are 2 group of series of this model.. now its clear the first group which include DS7 serial No doesn't had this socket.. and other group 2 did have.. and both groups didn't match by replacement as different hardware and firmware and driver of screen too... now its clear and the matter of this post issue too
                                • nomoresonys
                                  • 12276
                                  • U.S.
                                  Tim, what are the first 3 digits in your serial number?
                                  • Diah
                                    • Feb 2013
                                    • 6437
                                    for record and to let this post helpful to others too attached the list of all size Pfl with firmware link divided with beginning of serial No
                                    • TheTesterMan
                                      • Apr 2015
                                      • 91
                                      Was the original poster issue/failure ever resolved ?
