toshiba 50l1350u wont turn on
  • KenToshiba-owner
    • Jun 2016
    • 2
    • usa
    i have a toshiba 50l1350u that wouldnt power on regularly without unplugging it and repetitively trying over and over.. when it powers on its good till it shuts off. i updated the firmware and didnt have a problem with it for a few months.. then it started happening more and more.. i bought the PK101W0100I Power Supply Board Unit to fix this and it is doing the same thing.. all that ive read is the power regulator is shot or one of the fuses is shot but the power board was supposed to replace all that.. unless i bought a bad board im at a loss.. is there anything on the main board that can be doing this? im not a EE and cant replace anything with unsoldering it.. need any advise..
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: toshiba 50l1350u wont turn on
    Replace the main board
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Try reinstalling the firmware. Maybe you have an EEPROM which is losing data over time.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        +1 likely failed flash firmware on the SPI chip. Overtime with power cycles the firmware corrupts. Easier to replace the board than messing.
        • paulstef
          • Dec 2013
          • 724
          Anyone has a cheaper source than this mega-expensive ebay seller?
          https://www.ebay.ca/itm/EEPROM-1pc-T...EAAOxyDEVSdqgb
          Chip costs probably less than a buck...
          • nomoresonys
            • 12274
            • U.S.
            https://www.ebay.com/itm/PRE-PROGRAM...1/282414599471
            one there for 10 bucks free shipping, just took a quick look, make sure it's the right one if you get it.
            • paulstef
              • Dec 2013
              • 724
              Yep I saw this ad, unfortunately he doesn't ship to Canada . seems there is no other option for us...
              • nomoresonys
                • 12274
                • U.S.
                https://www.banggood.com/buy/eeprom.html
                some stuff here, looks to be eeprom programmers n such, probably not what you need but some interesting stuff.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  You don't mention the markings on the EPROM but the cheap CH341A programmer has read all for me so far.
                  Blank EEPROMs are available on ebay or Ali, perhaps the seller will sell you just the dump via email that you could program yourself if you can't find a dump.
                  You could try using freeze spray to aid in reading the one you have already, there are instances this will work, but no guarantee.
                  • nomoresonys
                    • 12274
                    • U.S.
                    https://www.youtube.com/watch?v=74E4gXlGyf8
                    Toshiba system reset, might help.
                    • paulstef
                      • Dec 2013
                      • 724
                      $3 for a programmer!! I'll try that out, thanks.
                      • nomoresonys
                        • 12274
                        • U.S.
                        https://support.toshiba.com/support/...eeText=3567373
                        • nomoresonys
                          • 12274
                          • U.S.
                          Finding the eeprom dump might be a major task. maybe 14 bucks isn't so bad.
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • brzostos
                            HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                            by brzostos
                            Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                            After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                            Original HP 150W power supply, the diode in the power socket lights...
                            10-01-2024, 01:34 AM
                            09-06-2024, 05:27 AM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • atltechnology
                            Toshiba Satellite L50 PSKXWA-01100M Schematic Diagram Board View
                            by atltechnology
                            I need the Toshiba Satellite L50 PSKXWA-01100M
                            This is my board no : daobltmb8fo rev f
                            model no : Toshiba L50D-C
                            Part no : PSKXWA-01100M
                            Give me Schematic Diagram Board View
                            01-14-2025, 04:21 AM
