Rca 42pa30rq
  • bjorkson
    • Apr 2012
    • 127
    Rca 42pa30rq
    Pick up a RCA 42PA30RQ plasma TV. Turn on the power button, the led light turns from red to blue, nothing comes on. I measure my voltage across my Y-main.
    Here's my reading on my Y-main. Getting the same on my X-main aslo, since they are both wired in series.
    Va=0, should be 55
    Vsc=6, should be 193
    Vs=6, should be 207
    So, do you think my Y-main is bad, or my PSU is bad since it's not outputting the correct voltage to my Y-main board? I check the PSU, seen all intact, fuse looks good also. Please advised. Thx
  • capkid
    • Oct 2010
    • 1339
    Re: Rca 42pa30rq
    There are quite a few threads about this TV and other similar Samsung-based TVs, so you may want to search the forum to gain more insight. The PSUs in these TVs rarely fail (I never ran into one in the five I worked).
    (1) Try disconnecting the X-main - check PSU voltages. If PSU voltages are normal replace the X-main.
    (2) If PSU voltages are still abnormal after step 1, disconnect Y-main from PSU. If PSU voltages are now normal, replace Y-main. I'd recommend replacing the Y-buffer as a precautionary measure, but they don't fail much. X-main may also be bad - check components on heat sinks for failures. If X-main components are bad, replace X-main.
    Note: Don't attempt to replace individual components on bad boards.
    LG Plasma Mal-Discharge Correction Service
    • bjorkson
      • Apr 2012
      • 127
      Re: Rca 42pa30rq
      Ok...let me try that tomorrow and see what I get. Will report back with my results. Thanks for your help.
      • bjorkson
        • Apr 2012
        • 127
        Re: Rca 42pa30rq
        OK...unhook the Ymain, unchanged on the voltage, unhook the Xmain, now I get 3v on my Va, instead of the initial 0 v. So, you think my X-main is the bad board? Nothing else changes.
        • bjorkson
          • Apr 2012
          • 127
          Re: Rca 42pa30rq
          Been reading some of the treads on this TV. I do not get a click on my relays when I turn the tv on, and there is no led light coming on on my main board also. So, could I have a bad PSU? or bad y/x main causing the PSU to shut down?
          • capkid
            • Oct 2010
            • 1339
            Re: Rca 42pa30rq
            You could try ruling out the control board or main board: https://www.badcaps.net/forum/showpo...22&postcount=2
            • freakorio
              Need Help To Identify Component on Ymain LJ41-05120A
              by freakorio
              Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
              05-21-2024, 02:32 AM
            • Renovator
              Samsung PN60F5500AF - Now it Glows
              by Renovator
              A friend called, a panel I helped install, had just made a pop and lost the picture, still had sound. No previous issues.
              Apparently, upon their further toggling there was another smaller pop. When I got there a few days later, No Sound, No glow, the front standby LED counting out a sequence. I pulled the back and the main/control board LED was in the 5 sec fault mode.
              I followed a diagnostic that Tom669 had helped a similar set owner with, at AVS:
              https://www.avsforum.com/forum/167-p...-has-sound-cap...
              06-20-2019, 11:33 PM
            • ReeceyBurger123
              PS50B430 Xmain Replacement Video
              by ReeceyBurger123
              Quick diagnoses and some things to check on a Samsung plasma that does nothing but click…..
              https://youtu.be/eTeB_GzwxhI
              03-08-2022, 01:59 PM
            • tieny
              PN60E535A3F Samsung Turns on but no Picture
              by tieny
              Wow, its been 5 years since the last time I posted here. Had been troubleshooting TV's for 3 years prior that while fixing hundreds of sets but now I can barely remember the basics of where to begin.
              So I just picked up this Samsung Plasma set. Couldn't resist the free stuff. The set will turn on (little chime plays) but there is no picture.
              Upon opening the back, the Vs and Va Voltages seem to be missing. They seem to be dropping off when the set first turns on. Vs starts at 211V and Va starts at 57V (The correct voltages from the label) and then steadily...
              07-20-2019, 08:16 PM
            • Axapotamus
              Plasma troubleshooting sound no picture
              by Axapotamus
              I have a 60” samsung plasma pn60f5300afxza. It started taking several tries to come on, got worse and has now quit coming on completely. I opened it up and checked power supply voltage. The vs and va voltages drop rapidly when power is turned on. Through process on elimination i found 2 connections that when disconnected from the main board; the vs and va voltages remain steady at 208 and 57 respectively. One is the white ribbon connector going to the ymain board. The 2nd is the 14 pin wire connector going to the x main board. Even with the xmain disconnected from the ymain, it still causes...
              07-14-2019, 08:05 AM
