I have a 60” samsung plasma pn60f5300afxza. It started taking several tries to come on, got worse and has now quit coming on completely. I opened it up and checked power supply voltage. The vs and va voltages drop rapidly when power is turned on. Through process on elimination i found 2 connections that when disconnected from the main board; the vs and va voltages remain steady at 208 and 57 respectively. One is the white ribbon connector going to the ymain board. The 2nd is the 14 pin wire connector going to the x main board. Even with the xmain disconnected from the ymain, it still causes rapid loss of voltages. If either or both of these are connected with any, none or all others connected to the main board the voltage steadily drops. Do i have multiple board problems or is this just a faulty main board or something else? Thanks in advance.
Plasma troubleshooting sound no picture
Assuming...7 Photos -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... - Loading...
