Da0p5hmb8f0 rev:f
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    Da0p5hmb8f0 rev:f
    I Need DA0P5HMB8F0 REV:F bios dump. thanks....
    add backup bin.
    • 21182
    Re: Da0p5hmb8f0 rev:f
    Post the full laptop model number and serial number.
    • kesmeseker
      • Jan 2015
      • 121
      • turkey
      model 15sq2038nt
      S/n 5CD112M5TR
      • kesmeseker
        • Jan 2015
        • 121
        • turkey
        Do you need another serial number?
        • peste
          • Dec 2016
          • 12954
          • ROMANIA
          add backup bin.
          bios extracted from the HP site update, the laptop has three bios variants, yours is 087FD..
          DMI 801000 - 8020FF
          KEYWIN 886000 - 88603F
          • kesmeseker
            • Jan 2015
            • 121
            • turkey
            thanksss
            • johansel
              • Feb 2022
              • 34
              • colombia
              Good afternoon, can you help me fix this file? The equipment turns on and off, it doesn't give an image.
              SN:5CD111QJGH
              model: 15-dy2040la
              Thanks in advance
                • 21182
                SN:5CD111QJGH
                model: 15-dy2040la
                Thanks in advance
                See post #5, your bios version is 087FD .Copy your DMI from your backup to the new bios using a hex editor,with the offsets provided.If you can`t do that yourself let us know
                • mydayparade
                  • Jan 2021
                  • 27
                  • philippines
                  im trying to copy from my backup bios the dmi to to peste
                  087FD file. but some details are not showing if somebody can do it for me it will be a big help. thank you.
                  MODEL hp 15-DY2073DX
                  Board: DA0P5HMB8J0 REV J
                  Serial No.: 5CD3307073
                  • peste
                    • Dec 2016
                    • 12954
                    • ROMANIA
                    the bios from post #5 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                    select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                    • mydayparade
                      • Jan 2021
                      • 27
                      • philippines
                      i try to do what your saying using the hex editor and look for the dmi but when i press ctrl+F to find those line
                      if only you can help to do it will be a big help sir
                      • peste
                        • Dec 2016
                        • 12954
                        • ROMANIA
                        learn to do it...I wrote above what to do, it's simple..
                        • Habble7
                          I need a BIOS dump for the Samsung S49CG934SU monitor
                          by Habble7
                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                          Suspected Cause:
                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • Citymin
                          NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                          by Citymin
                          My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                          The charging red LED lights up, but the charging screen doesn't show any indication.
                          When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                          (I've tried removing the battery and resetting the device, but the issue persists.)
                          NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                          PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • DynaxSC
                          MSI PRO B660M-G DDR4 - real bios dump from board needed (no stock bios)
                          by DynaxSC
                          Hi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
                          I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...
                          11-17-2023, 10:56 AM
                        • cekcons
                          g1 assassin Rev 1 bios dump - main and backup needed
                          by cekcons
                          main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                          thanks
                          01-23-2024, 03:26 AM
