Da0p5hmb8f0 rev:f
  • kesmeseker
    • Jan 2015
    • 121
    • turkey
    Da0p5hmb8f0 rev:f
    I Need DA0P5HMB8F0 REV:F bios dump. thanks....
    add backup bin.
    • 21667
    Re: Da0p5hmb8f0 rev:f
    Post the full laptop model number and serial number.
    • kesmeseker
      • Jan 2015
      • 121
      • turkey
      model 15sq2038nt
      S/n 5CD112M5TR
      • kesmeseker
        • Jan 2015
        • 121
        • turkey
        Do you need another serial number?
        • peste
          • Dec 2016
          • 13421
          • ROMANIA
          add backup bin.
          bios extracted from the HP site update, the laptop has three bios variants, yours is 087FD..
          DMI 801000 - 8020FF
          KEYWIN 886000 - 88603F
          • kesmeseker
            • Jan 2015
            • 121
            • turkey
            thanksss
            • johansel
              • Feb 2022
              • 39
              • colombia
              Good afternoon, can you help me fix this file? The equipment turns on and off, it doesn't give an image.
              SN:5CD111QJGH
              model: 15-dy2040la
              Thanks in advance
                • 21667
                SN:5CD111QJGH
                model: 15-dy2040la
                Thanks in advance
                See post #5, your bios version is 087FD .Copy your DMI from your backup to the new bios using a hex editor,with the offsets provided.If you can`t do that yourself let us know
                • mydayparade
                  • Jan 2021
                  • 27
                  • philippines
                  im trying to copy from my backup bios the dmi to to peste
                  087FD file. but some details are not showing if somebody can do it for me it will be a big help. thank you.
                  MODEL hp 15-DY2073DX
                  Board: DA0P5HMB8J0 REV J
                  Serial No.: 5CD3307073
                  • peste
                    • Dec 2016
                    • 13421
                    • ROMANIA
                    the bios from post #5 is virgin, use the HxD program (it's free on the internet), enter both bios into the program (your laptop and the virgin one),
                    select that interval mentioned in both bios, copy the interval in your bios and pass it to the virgin bios (copy - paste)....and that's it...
                    • mydayparade
                      • Jan 2021
                      • 27
                      • philippines
                      i try to do what your saying using the hex editor and look for the dmi but when i press ctrl+F to find those line
                      if only you can help to do it will be a big help sir
                      • peste
                        • Dec 2016
                        • 13421
                        • ROMANIA
                        learn to do it...I wrote above what to do, it's simple..
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers šŸ˜€,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
                          šŸ”§ Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          šŸ’€ Problem:šŸ˜…
                          - Device shows ā€œAdministrator Passwordā€...
                          08-07-2025, 04:54 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • DynaxSC
                          by DynaxSC
                          11-17-2023, 10:56 AM
                        • greelidd
                          K6604J Vivobook RTX 4070 BIOS Dump Request
                          by greelidd
                          Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                          Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                          09-01-2025, 06:14 PM
