Da0p5hmb8f0 rev:f
  • kesmeseker
    • Jan 2015
    • 117
    • turkey
    Da0p5hmb8f0 rev:f
    I Need DA0P5HMB8F0 REV:F bios dump. thanks....
    add backup bin.
    • 20611
    Re: Da0p5hmb8f0 rev:f
    Post the full laptop model number and serial number.
    • kesmeseker
      • Jan 2015
      • 117
      • turkey
      model 15sq2038nt
      S/n 5CD112M5TR
      • kesmeseker
        • Jan 2015
        • 117
        • turkey
        Do you need another serial number?
        • peste
          • 12557
          • ROMANIA
          add backup bin.
          bios extracted from the HP site update, the laptop has three bios variants, yours is 087FD..
          DMI 801000 - 8020FF
          KEYWIN 886000 - 88603F
          • kesmeseker
            • Jan 2015
            • 117
            • turkey
            thanksss
            • johansel
              • Feb 2022
              • 34
              • colombia
              Good afternoon, can you help me fix this file? The equipment turns on and off, it doesn't give an image.
              SN:5CD111QJGH
              model: 15-dy2040la
              Thanks in advance
                • 20611
                SN:5CD111QJGH
                model: 15-dy2040la
                Thanks in advance
                See post #5, your bios version is 087FD .Copy your DMI from your backup to the new bios using a hex editor,with the offsets provided.If you can`t do that yourself let us know
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • cekcons
                  g1 assassin Rev 1 bios dump - main and backup needed
                  by cekcons
                  main and backup ic dead so i cant post corrupt bios cause its 01 all over.
                  thanks
                  01-23-2024, 03:26 AM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
                • DynaxSC
                  Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                  by DynaxSC
                  I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                  It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                  I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                  11-06-2022, 05:22 PM
