HP ENVY 17-j016sg
  • mantza
    • Sep 2020
    • 36
    • GREECE
    HP ENVY 17-j016sg
    Hello, i have this laptop and it stuck on bios update and corrupted the bios, can somebody fix this original bios? i found another one and it works but wihout the correct info and it is slow to boot.
    laptop
    HP ENVY 17-j016sg
    board
    720267-501
    original bios
    https://www.sendspace.com/file/a9ljiy
  • peste
    • Dec 2016
    • 13566
    • ROMANIA
    Re: HP ENVY 17-j016sg
    laptop
    HP ENVY 17-j016sg
    board
    720267-501
    original bios
    next time post the backup of the bios here on the site ... try ..
    • mantza
      • Sep 2020
      • 36
      • GREECE
      i didn't work, the caps lock blinks and it doesnt turn on but i am trying update from usb
      • mantza
        • Sep 2020
        • 36
        • GREECE
        it didn't work, it does the same think, i can try to update from usb but after reboot its stuck again
        • mantza
          • Sep 2020
          • 36
          • GREECE
          i have put the other bios that was working and it completed the update also, i will leave it at that, thanks anyway
          • peste
            • Dec 2016
            • 13566
            • ROMANIA
            bios extracted from the HP site update, the laptop has two variants of your bios is 01966
            • mantza
              • Sep 2020
              • 36
              • GREECE
              ok, i didn't know this, i have closed it now, but thanks anyway
              • mikeybass
                Dell 9010 MT BIOS Update Always Fails
                by mikeybass
                Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                04-23-2025, 04:30 PM
              • akwky
                by akwky
                Hi!
                04-14-2025, 01:56 PM
              • al3m0di
                Update bios EFCN58WW to EFCN59WW
                by al3m0di
                Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                The BIOS version is EFCN58WW.
                When I turn on the device, it displays the message:
                "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                I've tried
                07-29-2024, 10:32 AM
              • capoplays
                Help with BIOS update on Dell G15 5515 after chip replacement
                by capoplays
                Hey everyone,
                I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                When I check the BIOS using the F12 menu Flash...
                10-24-2025, 06:53 AM
              • 0xx
                2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                by 0xx
                Hi folks,
                My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                I assumed that Windows Update was interrupted due to closing...
                09-14-2025, 03:46 PM
