Bad memory slot or memory controller?
  • yyonline
    • Jul 2009
    • 692
    So I have a new issue - one I haven't seen before.
    I'm working on a Compaq CQ60 laptop. It would post with memory in the top slot, but not the bottom slot. I figure it's a bad motherboard. So, I order a replacement board. I received the replacement the other day. What do ya know - the new board does the same thing... Posts with memory in the top slot, but not the bottom.
    Now, it would seem weird to me to have two motherboards with exactly the same issue. It's not out of the question, but it is unlikely. The memory has been tested and swapped with other known good memory. Same results every time.
    This laptop has a SI-42 AMD Sempron CPU. These have an integrated memory controller. Has anybody seen a CPU with a bad memory controller? Would it cause my issue? I'm just trying to get a feel for what should be my next purchase - another motherboard, or a CPU. Any input greatly appreciated.
  • toastygoodness
    • Jul 2005
    • 813
    Re: Bad memory slot or memory controller?
    i haven't seen any bad cpu with mem controllers, but it is likely. best to find someone with a similar chip and test.
    • NxB
      • Feb 2009
      • 1595
      Did you swap the chips? It won't post with both slots filled?
      • yyonline
        • Jul 2009
        • 692
        Yes, I swapped memory modules. Doesn't matter what modules were installed where. The only way it would post was with the dead slot empty.
        New CPU arrived today, and now both slots work. So, it looks like something fried the memory controller on the CPU. Memtest-ing it now.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          go figure... did you get another sempron or did you upgrade it?
          sigpic
          (Insert witty quote here)
          • weirdlookinguy
            • Sep 2007
            • 1638
            Egh. Sempron. My old laptop has a Sempron and it was/is a slow POS. I haven't touched the thing since I put together my new core 2 duo rig last fall.
            • yyonline
              • Jul 2009
              • 692
              Just another Sempron. Owner wanted it fixed as cheaply as possible. HP wouldn't warranty it, as it had damage from a drop. The laptop wasn't powered on at the time, and the drop damage seemed purely cosmetic. I don't see how a drop could cause CPU failure 6 months after it was dropped. But HP decided that they won't replace it under warranty as the warranty only covers defects, not damage.
                Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
                by sam_sam_sam
                This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
                Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
                07-07-2024, 02:34 PM
              • andrui742
                AMD FM2+ Board - Suspected Dead RAM Slot B1 - Seeking Diagnosis Advice
                by andrui742
                I'm helping a friend diagnose a desktop PC that is showing clear signs of a RAM slot failure. I would greatly appreciate your insights and experience on potential causes and any final diagnostic steps I might have missed. System Specifications:
                • Motherboard: ASRock FM2A58M-VG3+ R2.0
                • CPU: AMD A4-4000
                • Chipset: AMD A58 (Hudson D2)
                • RAM: Kingston 4GB DDR3-1333 (KVR13N9S8/4) - Two identical modules.
                Observed Failure Progression & Symptoms:
                1. Initial Intermittent Failure: The system would randomly BSOD in Windows 10 with a DRIVER_IRQL_NOT_LESS_OR_EQUAL error in
                Yesterday, 06:49 AM
                DELL Latitude 5591 Notebook 5000 Specification for Upgrade or Repair
                This specification for the DELL Latitude 5591 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5591 boardview and 5591 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5591...
                09-06-2024, 09:09 AM
