common SATA adapters that support SAS?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Anyone know of common SATA controllers that support SAS? Perhaps all I'd need is one of those SATA-SAS adapters and one of these controllers?
    Else will I have to get a SAS backplane and dedicated SAS card and all to access a SAS disk?
    Wondering about how I can use this one 146GB 15K RPM SAS disk I have. Disk was free, if infrastructure will cost $ARM$LEG then I may well just put the disk in the trash (or wait until someday I get a machine with a SAS backplane...)
  • diif
    • Feb 2014
    • 6978
    • England
    Re: common SATA adapters that support SAS?
    Nope, it won't work. You need a SAS controller.
    Ebay and get an SSD instead.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Thought most don't but there are some that do.
      Need a way to prove that the drive works... it *should* work but ...well, you know...
      • diif
        • Feb 2014
        • 6978
        • England
        A SAS controller can deal with SATA drives and SAS but a SATA controller can't talk to SAS drives.
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • reformatt
          Intel iMacs, 3rd party SSD failures and Fusion setups
          by reformatt
          I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
          As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
          So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
          12-18-2024, 10:34 PM
        • DynaxSC
          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
          by DynaxSC
          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
          The board is generally working now, all PCIe ports are working, Windows installs normally.
          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
          03-10-2025, 12:27 PM
          HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD i7-8700K Specification for Upgrade or Repair
          This specification for the HP Z2 G4 + 3TB SATA 6Gb/s 7200 HDD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 G4 + 3TB SATA 6Gb/s 7200 HDD boardview and Z2 G4 + 3TB SATA 6Gb/s 7200 HDD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
          09-12-2024, 03:28 PM
        • welp
          PS5 Disk Tray issues.
          by welp
          I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
          Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
          Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
          So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
          With that knowledge I preceded to check all the fuses for the 12v rail on the main...
          12-19-2024, 02:04 PM
