Delta AC-106A (Dell P/N 00G8CN) DC-DC converter repurposing
  • japlytic
    • Oct 2005
    • 2086
    This unit from a Dell PowerEdge R320/R420 has +3.3V/22A and +5V/22A DC-DC converters (one for each rail) which is a good candidate for conversion to a 12V input ATX PSU.
    Diagrams of required modifications regarding starting of the DC-DC converters is included with code at http://github.com/brycecherry75/ServerPSUtoATX which mentions required pullup/pulldown resistor placements and if required, simple level translators in the sketch.
    How to test protections:
    Overvoltage: Short (3.3V/5V)OVP pad to TEST_SGND
    Undervoltage: Short (3.3V/5V)UVP to its respective TEST_(3.3V/5V) pad
  • redwire
    • Dec 2010
    • 3910
    Re: Delta AC-106A (Dell P/N 00G8CN) DC-DC converter repurposing
    You got 12VDC output without rewinding the transformer?
    • japlytic
      • Oct 2005
      • 2086
      I used a server PSU with a +12V output as an input with this output being switched along with the +3.3/+5V DC-DC converters.
      • redwire
        • Dec 2010
        • 3910
        I couldn't quite understand the project because I don't know servers using 12V power. Used to ATX from mains power.
        It looks like you modded the Power_OK signal and there is even a sketch which looked as a really nice way to generate it instead of the usual mess of many comparators and fudging that in the power supply.
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
          This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-07-2024, 03:40 AM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • Dynamite76
          Dell D635EF DELTA DPS-635AB PSU with blown TNY280PN
          by Dynamite76
          Recently I got a DELL PSU from a presision T3600. It is a 635W PSU which went out with a bang and some black smoke. The model of the PSU is a D635EF made by DELTA.
          The cause of the bang was a blown. TNY280PN Chip. How ever as a result or as a causo also two SMD resistors are smoked. I have been able to replace the TNY280 Chip but I do not know the values of the resistors. The resistors are within the Drain line of the TNY. I can not find the schematic of this PSU. THe resistor are Open Loop and on the voltage accross them is about 330V. (EU)
          Any suggestions for...
          07-27-2023, 01:52 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
