Unlock password protected SSDs
  • Verlengsnoer
    • Sep 2016
    • 110
    • Netherlands
    hi, i have a bunch of ssds, and those are password protected and unusable,
    are there ways to unlock them?
    i dont know what data is on it, and its fine to reformat them.
    hope someone has ideas to unlock the ssds
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: Unlock password protected SSDs
    if you don't need them data, does it let you totally do a sector wipe?
    • Verlengsnoer
      • Sep 2016
      • 110
      • Netherlands
      no, tryed serval tools to reformat, but getting messages as I/O errors, or not accesable device, and other warnings
      so no, it doesnt let me do a sector wipe sadly,
      only thing the ssds to, is it detects as a 128 gb ssd drive, from samsung with its type nr, when u try to boot of the disk it asks for password, or screen goes black.
        • 31288
        there is a command that makes drives factory-reset,
        you need to send it direct - no usb adapters, and you probably have to use linux.
        • Verlengsnoer
          • Sep 2016
          • 110
          • Netherlands
          and what command do i need?
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Maybe this will set you off in the right direction:
            https://www.badcaps.net/forum/showpo...1&postcount=35
            • Verlengsnoer
              • Sep 2016
              • 110
              • Netherlands
              thanks, but sadly not, psid revert is not supported on the drives,
              i dont get why they dont work, the samsung magician software does detect the ssds, the written tbs and temperature is readble, but i cant format the drives or something in that way, so yeah, no psid revert support, no format possible, weird never liked samsung, but ok,
              tryed serveral format applications, no result, try install windows on it, not working.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                That is a waste of both your and our time.
                You have not told us what drive you are trying this on.
                In any case you can't format or do anything with the data on the drive before you do a psid revert.
                A Linux machine with hdparm and sedutil are probably the best ways to go at it.
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1866
                  Probably an absurdly extreme measure, but have you tried running a FW update ISO from the manufacturer? As far as I can guess, those should reset the password?
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                  • Verlengsnoer
                    • Sep 2016
                    • 110
                    • Netherlands
                    i have this problem with 23 samsung ssds drives, but different types, but wil try the linux based tools
                    • jm801
                      Banned
                      • Apr 2020
                      • 123
                      • monterrey
                      Has anyone been able to unlock the ssd m2 or someone knows how to do it I hope you can help me I have 5 m2 blocked
                        • 31288
                        you would need to know the part number on the controller chip.
                        • jm801
                          Banned
                          • Apr 2020
                          • 123
                          • monterrey
                          which chip is to look for it
                            • 22146
                            look at all the QFN IC`s ,get the part number from each and do a google search ,one of them will give results as the controller IC.
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • Godfather79
                              Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                              by Godfather79
                              Hello everyone in the community
                              Dear Sir,
                              I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                              Problem details:
                              * Model: Dell Latitude 5520.
                              * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                              * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                              * Service Tag: (Enter your actual Service Tag from the laptop here)
                              * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                              11-08-2025, 10:04 AM
                            • Nopslide
                              HP Omen 15-dh0052nf power-on & bios password
                              by Nopslide
                              Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                              My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                              Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                              04-01-2024, 04:27 PM
                            • chunhualo
                              Please Help unlock bios password for Alienware 13 r1 bios password 7digit service tag
                              by chunhualo
                              HI I have forgotten my old laptop Alienware 13 r1 bios password .
                              Can anyone find the master password for my laptop
                              The service tag number is : 2JJVH12
                              03-16-2025, 04:13 AM
                            • Zain Ahmas
                              unlock bios password ADVAN soulmate apn21s.
                              by Zain Ahmas
                              help me to unlock bios password ADVAN Soulmate board code: apn21s
                              11-10-2025, 01:14 AM
