Lenovo think center 73M Desktop shutdown issue?
  • ivtec
    • Dec 2008
    • 1967
    Hi guys; i have here a Lenovo think center 73M Desktop, i have 2 HDD with Win10 installed ,and 1 shuts down properly, when i use the other HDD it wont shutdown properly, the power supply and motherboard stays on with the green light, only turns off HDD, i tried a few known fixes but no avail,it's kind weird cause the Win install of the one that has the power issue is fresh and updated.
    • 31301
    Re: Lenovo think center 73M Desktop shutdown issue?
    it's not doing some stupid shit in the settings like going into "sleep mode" is it?
    • ivtec
      • Dec 2008
      • 1967
      It goes in sleep mode but doesn't come up from it , when press enter, if i restart pc it does start normal, when i shutdown it wont shut down stays with the green light on, and to turn it off i have to press power button on desktop if i want to turn it on back on again, well now i'm using the HHD that works fine, i have 3 other Lenovo Think Center desktops ,i'll keep this HDD to try on the others when i have issue, thanks
      • shahnld
        Lenovo legion 5 pro startup issue
        by shahnld
        Good day Experts
        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
        08-24-2025, 12:31 PM
      • grimacelord
        by grimacelord
        Hello there.
        History:
        03-15-2023, 03:29 PM
      • riko 656
        Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
        by riko 656
        I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
        Laptop Model:
        • Model: Lenovo Legion Slim 5 16APH8
        • GPU: NVIDIA GeForce RTX 4070
        • Main BIOS chip size: 32MB
        • VBIOS chip size: 16MB
        Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
        What I Have Tried So Far:
        1. I
        11-04-2025, 05:14 AM
      • db80
        Lenovo Ideapad 5 15ARE05 startup issue
        by db80
        Hello friends,
        I've been racking my brain over the past few months on the following issue:
        I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
        If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
        Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
        I tried all the common alleged „fixes“...
        07-06-2024, 05:58 PM
      • coasterghost
        Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
        by coasterghost
        For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
        Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
        Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
        System Hardware:
        Processor: AMD Ryzen 7 PRO 5850U
        Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
        09-08-2025, 10:46 PM
