VMware player 3.0.1 crap emulation sound
  • ZuluLima
    • 35
    • U.S.A.
    I'm trying to use Windows 95 and 98 first edition on Vmware player v3.0.1 and the sound emulator is es1371 (ensoniq pci sound blaster) rather than sb16 or sb32. The es1371 drivers are meant for the second edition. And the es1371 or the es1370 drivers will not install without a BSOD. The SB16 or 32bit compatible drivers will not work at all off the win98 disc in VMware. When it comes to Virtual pc 2007 the disc drivers work too good. I do have both 2007 and VMware player installed. The physical sound card is an Audigy 2 ZS pro.
    For default the .VMX file goes:
    sound.present = "TRUE"
    sound.fileName = "-1"
    sound.autodetect = "TRUE"
    svga.autodetect = "TRUE"
    sound.virtualDev = "es1371"
    Then I tried:
    sound.virtualDev = "sb16"
    Then:
    sound.virtualDev = "sb32"
    That did nothing. Does anyone know where to get good Ensoniq drivers?
    Also does anyone know how to get USB enabled in Microsoft Virtual PC 2007?
  • ZuluLima
    • 35
    • U.S.A.
    Re: VMware player 3.0.1 crap emulation sound
    I looks like I'm gonna need an Ensoniq driver for Windows 3.1 also. Why did they decide on Ensoniq? Also I forgot to say that the host system is windows XP.
      MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
      This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
      09-06-2024, 05:30 PM
    • kokopelli75
      Victrola multi-player - No audio
      by kokopelli75
      Hello!
      My mother has a Victrola Navigator player that stopped functioning after a storm. I checked out what I could - all player functions appear to work, but there is no audio output in either the speakers or the headphone jack. I suspect (with my limited knowledge) that the amplifier part of the device is toast. Photo of the suspected board is attached. There's separate boards for front display, record player, etc. This board has a section for power regulation and a section for amp. There's a UTC7266 7+7W dual bridge amplifier IC and a CSC2314F sound processor IC on the board. Visually,...
      01-11-2025, 03:51 PM
    • unimatrix93
      LG BH6420P Home theather blue ray player repair
      by unimatrix93
      Hello everyone, I'm trying to troubleshoot this LG hometheater player.
      The customer forced her USB drive reversed into it's USB socket and since then the player won't work properly, only shows "Please wait" error forever on it's display.
      Now I started diagnosing the USB socket and the mainboard where it's connected.
      I found 20ohm resistance to ground on the 5V line of the USB.
      5V is missing and I found the buck converter of the USB line, TPS65252 IC.
      After measuring the pins I realized that both VIN and 3V3 is correctly present...
      12-10-2024, 10:31 AM
    • FZG
      Panasonic AG-1000B VHS player with bad picture quality
      by FZG
      Hello!
      I recently got an old VHS player from Panasonic and just for fun I want to try to repair this device. It is an AG-1000B portable VHS player from 1990 and it has a problem with picture quality in playback mode.
      Picture in playback mode is very noisy and often loses sync but the still images are nearly perfect.
      I want to know, is this something that could be solved by recapping or is the video head likely gone?
      Also, what mechanism is this?
      Any feedback is appreciated!...
      05-06-2024, 07:16 AM
    • samson7point1@yahoo.com
      Help troubleshooting an audio problem with an RCA SGT-250 CED Player
      by samson7point1@yahoo.com
      The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
      The player processes the audio signal using two different reference frequencies. The "R"...
      04-30-2024, 11:22 AM
