Hurricane Katrina impacts semiconductor wafer supply
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Peter Clarke
    EE Times
    (09/09/2005 8:49 AM EDT)
    LONDON — Hurricane Katrina has caused the shutdown of a New Orleans facility owned by Air Products and Chemicals Inc. that produces hydrogen used in the manufacturing of silicon wafers, a development that could impact global production of semiconductors, according to market research company iSuppli Corp.
    Hydrogen is used in the deposition of epitaxial silicon films on wafers, and the industrial gas complex in New Orleans is the site of much of Air Products' hydrogen manufacturing activity, iSuppli said. These films are critical in the manufacturing of higher-voltage semiconductors used in power management applications, iSuppli said.
    PeteS in CA
  • magneh
    Is this some kind of fuse resistor ?
    by magneh
    Hello guys
    Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
    Seem to me like some kind of fuse resistor?
    After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
    They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
    The red band is larger than the 4 others, but I dont have much experience with these components.
    Also one of the orange...
    02-10-2025, 07:54 AM
  • harp
    Metod for removing glued heatsink from fragile component
    by harp
    I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
    06-23-2025, 02:01 PM
  • adigrf
    How can I find this chip equivalent?
    by adigrf
    Hello! I saw on my motherboard DAG77MB18C0 rec C that I have a burn chip and I also found a similar one in good shape but I am having troubles recognizing and finding it online in order to replace it.
    What I can read is: DN46AP 22cf 1000 and Gemini is telling me it is a MOSFET by On Semiconductor model NVMFD5c466n
    Do you think this is real ?
    The laptop is still starting but I dont want to use it until I replace that. Based on the images, do you think I will succed with a profesional electronic technician?
    06-22-2025, 12:37 AM
  • Exim
    ASRock N100M, no picture no boot, but semi-alive
    by Exim
    Hi guys,
    I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
    ASRock N100M special features:
    - CPU soldered to board, small Intel 12th gen
    - iGPU
    - four POST LEDs
    Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
    I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
    Symptoms:
    - no picture/signal on any of the display connectors,...
    04-01-2025, 02:36 PM
    BrightKing KD07 Metal Oxide Varistors (MOV) Datasheet
    Metal Oxide Varistors (MOV) Data Sheet
    Features
    ● Wide operating voltage (V1mA) range from 18V to 820V
    ● Fast responding to transient over-voltage
    ● Large absorbing transient energy capability
    ● Low clamping ratio and no follow-on current
    ● Meets MSL level 1, per J-STD-020
    ● Safety certification: UL: E327997 CSA: 246579 VDE: 40027827
    Applications
    ● Transistor, diode, IC, thyristor or triac semiconductor protection
    ● Surge protection in consumer electronics
    ● Surge protection in industrial...
    10-07-2024, 05:58 AM
