Windows 10 Nvidia Custom Resolution issues
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Here's a headscratcher for you all:
    Installed windows 10 on an old Dell Optiplex 760 with an Nvidia GeForce 730 GT for my dad.. exercise machine #2 (running two different e-cycling apps on two machines to get points in both at the same time ).
    I'm trying to get it to work with an old 720P TV over VGA (no digital support, it's that old!).
    Here's the issue: it's a picky eater when it comes to resolutions. 1280x768 @ 60Hz Interlaced makes it happy. However, for some bizarre reason, things default to what I beleive is 1280x1024 &75HZ which the TV doesn't support.
    I hooked in another monitor over DVI and was able to set the correct resolution... but as soon as I unplug the other monitor, windows/nvidia control panel switches the TV resolution back to the unusable setting...
    If it matters, when a DVI monitor is connected, that monitor is reported as #1, and the TV is kicked down to #2. Even if I connect the DVI after starting up with VGA connected.
    Is there a way to force the VGA output to the correct custom resolution?
    Yeah, I know the correct solution is to baseball bat the entire setup and get something newer... but we're both cheapskates and want to see if we can make it work.
    sigpic
    (Insert witty quote here)
  • hasefroch
    • Apr 2013
    • 42
    • Argentina
    Re: Windows 10 Nvidia Custom Resolution issues
    Looks like the VGA out of your TV does not provide a EDID or is corrupt, then ignored by windows.
    Back in the day, (between win98 and xp), I used to fix it using the software Powerstrip; it would let me read directly the EDID from the monitor or the registry values for said monitor, and the most valuable for me: build your own custom drivers based on the values of your choosing (max resolution, max freq H and V, etc) and export them as a .inf file so you can install it as custom driver of your monitor.
    I have no idea if Powerstrip still work under windows 10, but in a pinch you can search for a EDID dump from a monitor with the resolutions that you need, then install them to let windows override the data from the monitor.
    Here you have some initial how-to from microsoft:
    https://docs.microsoft.com/en-us/win...-monitor-edids
    And a repository of EDIDs from where you may find one compatible with your TV:
    https://github.com/linuxhw/EDID
    Do note that there are 38238 monitors in this repo
      master hoarder
      • May 2008
      • 12175
      I don't remember the correct nVidia terminology in my head here... but if you go into the nVidia control panel, there should be an option to only allow EDID-compatible resolutions. If you uncheck that, you can set the maximum allowable resolution and refresh rate the video card can output. ATI has a similar option and that's what I'm using on my gaming PC right now to run 1152x864 @ 85 Hz on a 19" CRT that supports that resolution just fine but the ATI drivers/software for some reason doesn't allow in Windows 7.
      As for Powerstrip - yeah, that one was a classic back from the Win 9x / XP days to set your monitor resolution and refresh rate correctly. These days, though, I think most version of nVidia and ATI software give you just about enough control where you don't need PS. But for an older system, PS is still handy to have.
      • piernov
        • Jan 2016
        • 4437
        • France
        If you can't get it to work with the drivers, you could also buy (or maybe make) an EDID emulator, you plug it in between inline with the VGA cable and it reports a bunch of common modes.
          • 31090
          if it's still there, disable the plug&play monitor option.
          • prtysrss
            • Feb 2021
            Can you set the frequency/ ignore EDID in Nvidia control panel? I was able to move the frequency of my TV up or down a few HZ without it crashing, i think when you go to custom resolution you can define a refresh rate, at least on my Lenovo P15 and P1 (Quadros)
            • RJARRRPCGP
              • Jul 2004
              • 6304
              IIRC, NT-based Windows is more picky than Windows 98 and ME!
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • piernov
                NVidia bumpgate
                by piernov
                Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                May complete this post at a later date with more details.
                Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                03-27-2021, 10:34 AM
                by momaka
                03-15-2023, 10:17 PM
              • Jesus Coder
                Issues Reviving Old Dell 2408WFPb Monitor
                by Jesus Coder
                I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                06-25-2023, 02:33 PM
                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                10-02-2024, 08:52 AM
              • wattage
                by wattage
                Hello Badcaps Community,
                07-13-2025, 04:41 PM
