pre-emptive cap replacement
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: pre-emptive cap replacement
    are you sure that Ellyt is the brand? i have seen several catalogues to use that as a general description for electrolytic caps. tell us the writing on a cap or show a photo
    • Kiton
      • Dec 2005
      • 7
      Okey, sorry about that
      This is what it says:
      Sanyo 2200 uF, 6,3V
      On the other side it says:
      105 degres s.e56 wx
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        yes they will be fine. where did you buy them?
        • Kiton
          • Dec 2005
          • 7
          Ok, I need some more help. I have a friend who is replacing the caps but we ran in some trouble. I thought all 25 caps where the same. He saw that they were different after he took them of the motherboard. Now we don“t know which is going where.
          So i would be very grateful if someone could point out which of the 25 caps is the ones that are 1000 uF at 16V.
          • Kiton
            • Dec 2005
            • 7
            I got them from a swedish store...
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              #26
              how many of each cap do you have?
              • Kiton
                • Dec 2005
                • 7
                #27
                I bought 25 caps that had the 1800 uf 6.3V
                So I need to go to the store tomorrow and get five 1000 uF 16V
                He who took it apart got 20 caps of 1800 uF and 5 caps of 1000 uF. from the motherboard.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #28
                  sheldon provided a list of the caps and their positions that are written on the board (many thanks sheldon)
                  "iMac G5 20"" 1.8 GHz Model"
                  Left to Right Through-hole Electrolytic Caps
                  C1109 1800 uF 6.3v
                  C3411 1000 uF 16v
                  C3311 1000 uF 16v
                  C1008 1800 uF 6.3v
                  C3422 1000 uF 16v
                  C3412 1000 uF 16v
                  C3321 1000 uF 16v
                  C3427 1800 uF 6.3v
                  C3418 1800 uF 6.3v
                  C3328 1800 uF 6.3v
                  C3320 1800 uF 6.3v
                  C3474 1800 uF 6.3v
                  C3317 1800 uF 6.3v
                  C3472 1800 uF 6.3v
                  C3332 1800 uF 6.3v
                  C3475 1800 uF 6.3v
                  C???? 1800 uF 6.3v
                  C3473 1800 uF 6.3v
                  C3333 1800 uF 6.3v
                  C2208 1800 uF 6.3v
                  C2209 1800 uF 6.3v
                  C5009 1800 uF 6.3v
                  C5008 1800 uF 6.3v
                  C908 1800 uF 6.3v
                  C909 1800 uF 6.3v
                  • Kiton
                    • Dec 2005
                    • 7
                    #29
                    could you be more specific?
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      #30
                      The list above shows which capacitor value corresponds to what is written on the board next to each capacitor. if you check the photo above, you will see what the writing on the board looks like.
                      I do not have enough photos to be certain about all the capacitors.
                      in the below photograph in yellow is shown what i see from the photos to be the 1800s. In red is an area with 7 capacitors. of those 7 capacitors i believe that 2 are 1800 and the other 5 are 1000.
                      these values should correspond to those 7 capacitors
                      C1109 1800 uF 6.3v
                      C3411 1000 uF 16v
                      C3311 1000 uF 16v
                      C1008 1800 uF 6.3v
                      C3422 1000 uF 16v
                      C3412 1000 uF 16v
                      C3321 1000 uF 16v
                      if the list does not agree with your board then do not proceed with the job because if you put a 6.3 at a position where a 16v should be it that capacitor will not last long.
                      i will ask sheldon to come by and check what i have said.
                      • Kiton
                        • Dec 2005
                        • 7
                        #31
                        Thanks! Just need to be shure that he didn“t do a typo.
                        My Imac is my baby
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          #32
                          this photo looks good. i think the 1000s are the X capacitors. if this agrees with Sheldon's list then go ahead.
                          • stokessd
                            • Aug 2005
                            • 13
                            #33
                            I have more pics here:
                            http://www.quadesl.com/albums/imac_cap_pics/
                            I had a problem locating short caps that would fit into the iMac chassis. I had one cap that was bulging and I called apple and they came out and replaced my power supply and midplane. No fuss no muss. Came right to my house.
                            So I never did a cap replacement. If you do replace caps yourself be careful of the height of them, particularly the ones near the middle by the stand.
                            Sheldon
                              Lenovo ThinkPad L13 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad L13 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 + 3YOS Warranty boardview and L13 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-07-2024, 04:30 AM
                              Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) L Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad L13 Yoga + 3YOS Warranty Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L13 Yoga + 3YOS Warranty boardview and L13 Yoga + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              Lenovo ThinkPad L15 + 3YOS Warranty Notebook L Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad L15 + 3YOS Warranty Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L15 + 3YOS Warranty boardview and L15 + 3YOS Warranty schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
