sony vgnnr21e/s it
  • pippo_one
    • Aug 2010
    • 127
    • Vicenza
    sony vgnnr21e/s it
    Hi all, i have a sony vgn-nr21e / s it dusted off from the attic. after installing w7 i tried to replace the two 1gb ram banks with two 2gb but the pc crashes.
    on the sony site in italy the drivers and bios are no longer available. Can anyone help me? I think and hope that if you could update the bios the crash problem would be solved
    thank you in advantage
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5045
    • US
    Re: sony vgnnr21e/s it
    Sonys site wasn't much help. No specs really listed. No bios update
    But I did find out that it literally does not support 4gb, it supports two.
    Sometimes these things can be iffy so try 3gb. If the limitation is 2gb (or three) install win 7 32 bit. 64 has the windows SxS (side by side) system for compatibility with 32-bit programs and it takes up some ram itself
      • 31294
      sony are fuckers - i'v been through the bios hunt so many times,
      try sony sites in lots of different country's, believe it or not they have different content.
        • 22191
        They dropped support for vista nd win 7. The max supported ram is 2GB .
        • piernov
          • Jan 2016
          • 4439
          • France
          Chipset doesn't support 4GB of RAM for sure. It may work with 3GB, only way to know is to try.
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            Yeah I had a DV1000 that didn't support 4, it listed it as maximum support for 2. But I did get three working with no problem
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
              Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
              This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 05:27 AM
              Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
              This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
              09-06-2024, 05:30 AM
              Sony VAIO VGN-SR29VN/S S Specification for Upgrade or Repair
              This specification for the Sony VAIO VGN-SR29VN/S can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-SR29VN/S boardview and VGN-SR29VN/S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
