SS56G Motherboard KTS24.5G1e broken
  • rmurphyr
    • Nov 2009
    I have a Shuttle XPC SS56G1 that I believe has a couple of bad capacitors. It is also missing a component at location X5. It is a small silver can like part that is laying horizontally and has the number KTS24.5G1e stamped on it. Before I replace the capacitors I need to find out what this part is and where I might buy one. Any help would be appreciated.
  • glovecaps
    by glovecaps
    11-25-2024, 04:23 PM
  • Archimedes
    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
    by Archimedes
    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
    Fans are spinning. Blindly could install windows11 and got the device manager...
    07-30-2024, 05:14 PM
  • barrymoats
    Issue with Shuttle SS56G Motherboard KTS24.5G1e
    by barrymoats
    I have a Shuttle XPC SS56G1 that I suspect has some faulty capacitors. Additionally, there's a missing component at location X5. This part is a small silver can, positioned horizontally, with the number KTS24.5G1e stamped on it. Before I replace the capacitors, I need to identify this part and find out where I can purchase one. Any assistance would be greatly appreciated.
    06-11-2025, 03:41 AM
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
    ASUS P5GC-MX motherboard recap
    by momaka
    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
    So here is what the motherboard looked like with its original caps:
    CPU VRM area up close…...
    01-27-2021, 11:59 PM
