Screwed up IDE/PATA Mobo Socket
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Dang it! I opened the case of my wife's old Dell GX 180 to clean it out, and upgrade the video card yesterday. I forgot that I had used a non-Dell short IDE ribbon cable to connect the DVD drives. My mind saw that the cable was being pulled tight and that I was busting something but my hand kept opening the case anyway. "Bad Hands!" The cable cracked the plastic, and bent the pins on the mobo Primary IDE socket. Since the socket comes off the board and turns a 90 I had to take the tray out to attempt to straighten the pins. I got it good enough so that the cable would plug in it again, and none of the 40 pins are bent over. Well the black plastic clamp that holds the ribbon wire in connection with the ribbon's plug also busted. I reused the wire because I didn't feel like looking in my junk boxes for another cable. The cable is now bad and the drives give errors on the read. Now I have to take her desk apart again just to get the PC out to replace this stupid cable. Dang it! I think I will dust and clean mine today and see what I can bust in it! I bet its a bitch to replace one of these IDE conectors too.
    Mark Twain
    John Paul Jones
    Rod Serling
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Screwed up IDE/PATA Mobo Socket
    pics please... the connector shold be ok, so my guess is the cord.
    sigpic
    (Insert witty quote here)
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      Would love to give you pics but the wife busted the digital carmera a while back. Her web cam isn't hooked up right now and I just don't want to mess with that old nest of snakes right now.
      Mark Twain
      John Paul Jones
      Rod Serling
