I got a working 16X DVD out of a junk PC. I did a firmware update on it , and trashed it. The drive is a MadDog NEC ND-2500A. Somehow I picked the wrong update for it. Now it can't read anything. It now shows up in my system as a NEC ND-2510A drive. I downloaded the right firmware update now but it will not flash my drive back to a NEC ND-2500A. The progie says that my drive does not show up right and aborts the flash operation before it even starts. Well I guess it does show up wrong now since I put the wrong firmware in it... Is there anyway to save this drive, or is it "just another brick in the wall" after my fine work...LOL I need something that will run in windows or from a cold boot. This is and Xp PC right now, and I don't know how to do anything DOS with it. If needs be I could put linux mint or kubuntu back on it to fix the drive but I'd rather not. I use the Mint on my Lappy.
I Bricked My ND-2500A DVD Drive!
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod SerlingTags: None -
Re: I Bricked My ND-2500A DVD Drive!
Whats a JTAG interface? What does it look like. Please post a pic if you can."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
Do you use the Windows-flasher? If so, a DOS-based flasher might do the trick. There is also a third party flasher, used by those who transflash drives with alternative firmware. As I understand it, it ignores previous firmware versions before flashing. There is also this selection of official and unofficial firmware for this drive.------------
Be a menschComment
SofTest if I make a windows Xp start floppy in windows, when I start the PC with it am I now in "True DOS"? I did find a DOS based flasher for my drive someplace but I didn't know how to run my Xp PC in DOS mode at that time. The flasher I found said that in could not be run in a windows DOS box. It had to be run in true DOS. The other options I have of starting this PC in DOS are the good old windows 98, and windows ME start floppy disks. I guess I could also switch out my hard drive and put a little one in it just to run good old DOS on the PC to try and save the DVD drive. I think that this would mean that I would also have to find DOS based drivers for the dive, and my mouse first if they exist. This is enough to make a guy want to drink a beer at 5:00am in the morning....LOL"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
Its Alive!!! It reads DVD's, and CD's now.Thank you Pentium, and SofTest. Far Out! I still have to do a DVD test burn but I think that it will work.
First I used that bin flasher with a patched bin file from the dangerous brothers. This made it come back to life. Next I used the 1.07 update from NEC, and flashed the drive again. My software takes care of the region BS so I don't need the dangerous brothers patch. The drive now shows up as NEC ND-2500A 1.07....ect.I'm going to do that test burn now. Thanks again you two!
Let me buy you all a beer
Mark Twain
John Paul Jones
Rod SerlingComment
All it can do is read disks now. As soon as the actual burning part of a DVD copy is started the drive fails to burn it. Its no big deal. It was free, and I guess that I killed it. It just may be time to buy a $49.00 Plextor drive from Tigerdirect. I'm not having too much luck with the DVD burners from the junk bin these days, but if I had left this one alone it would have worked just fine.
Mark Twain
John Paul Jones
Rod SerlingComment
Originally posted by seancNew DVDRW drives can often be picked up for about £15 - the NEC and Liteon drives don't seem to be so hot. LG drives seem more reliable.Comment
by codernov
https://i.ibb.co/Z1hKTkwW/0001.jpg
https://i.ibb.co/BK7YmhHx/2025-06-06-16-14-IMG-5818.jpg
This thing is pretty expensive. More than an average notebook.
Anyway. I got this job over facebook market place. Customer said he bought it used and it was working fine, then he decided to upgrade firmware and somewhere along the way the battery died or whatever we don't know, it got bricked. That's his story and he's sticking with it.
If we connect power supply to it, we are getting 21 milliamps and nothing is happening. Pressing buttons does nothing....-
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo -
by perfm2So I've worked on dozens of HP and Dell laptops and have never encountered this before.
Steps taken in my usual process.
Reset security settings in the BIOS
Ensure existing HD comes up into the OS
Shut down the laptop and disconnected the main battery
Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
Replace battery connector and close up the laptop
Insert my USB drive with my Windows 10 image I've... -
by jordi90Hi,
I was given a laptop with a BIOS locked by a password. I read that one way to unlock it is to read the EEPROM contents, patch them, and write them back. I was using the typical CH341A programmer and clip to do this, but because the clip is so loose, after patching the dump I accidentally placed the clip on the wrong EEPROM and now the laptop won’t boot.
Can I do something to fix it? I’ve attached photos.
...Today, 01:08 PM -
by reformattI thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...12-18-2024, 10:34 PM - Loading...
