Had an idea I might or might not do because it might be somewhat pointless and...
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    my title was too long and wanted to add:
    ...and as TC knows I have a short attention span (EG: the caps database failure-LAMP project). Well, that project I had actually finished the software, but alllll those datasheets. Most of them were image scans from the crappier companies (cause there were more crappy companies, many didn't exist anymore) so I had to use OCR -> Excel (re-organize rows) export-> Tab delimited -> Pasted into textbox and parsed into database (that process I was actually proud of, some of my best PHP coding)
    but many sheets were old, incomplete, some products had incomplete/odd stats. So after a few weeks I gave up and just made the datasheet archive
    My new idea? I remembered my last job (public computer repair shop) the owner had a custom php-mysql based local hosted website for repair tickets. It was decent, but I had an idea to make a win32 based one (VB.net 2008)
    Instead of using obdc or mysql (which requires a connector), I was thinking of using https POST to a PHP script with localhost database access that fed xml into the program. This way the database isn't directly exposed, so wild exploits can be blocked
    Doing research into it, I actually found a number of pieces of shop software that were cheap/subscription or one-time fair priced ($100-200). That had extensive features (some though even I see how to implement).
    though frankly I was going to make it freeware/closed source (except for the PHP side obviously).
    The program/database interaction of this sort is actually something I had experience with. A few years ago I tried to make an ultravnc launcher where my support client would connect and login to a my website, store my IP in a memory table, have the customer support program read it, and launch ultravnc with a reverse connection to my ip address on a specific port (forwarded on router), which was specified by my side, to coincide with the local computer I was on (my shop box say was port 9500, my laptop was 9501), port specified when I logged into the software.
    this surprising amount of odd hellish half-assed non-proxyed software actually worked...most of the time. Didn't have an auto-reconnect, and had random times where it just would not connect at all. Even built a chat system between customer and me into it. That usually worked, though sometimes the colors/font didn't work right no matter how hard I tried to fix it. Was built with VB 2005 though and that might have had limitations/bugs.
    then I discovered teamviewer and said screw it. I don't get enough business to make teamviewer suspicious and I don't really get paid for helping my customers post-repair
    what do you guys think? should I make a ticket management system for maybe myself for fun (though I haven't done VB/PHP in a long time, so it probably won't be fun). Something I shouldn't even bother with?
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Had an idea I might or might not do because it might be somewhat pointless and...
    IMO, there are two primary (non-commercial) reasons to take on any non-trivial project:
    1. you can actually use the resulting project (at a lower "cost" than the development effort would imply)
    2. you want a REAL application (instead of a TOY application) to develop some new skillset around
    See where your attitude towards it fits these.
    • Dreigas
      Laptop/motherboards database
      by Dreigas
      Does anyone know, from where shops get information about laptops? Does any paid/free database exist?
      I'm very interested in the database, which should have a phone/laptop model number and which motherboard they have inside. Also will be good about product specs (but this is not very important for me).
      Or maybe you just know some websites, which can provide this information? Just enter the laptop model number and I will get the motherboard model number.
      Thank you for any info and your time!
      09-16-2023, 08:22 AM
    • Troystain
      Help EZP2023+ updated chip database for w25q256jveq?
      by Troystain
      Hello, anyone here have updated ezp2023+ chip database in .dat file format.
      I need to add w25q256jveq chip but I do not know what data should I type.
      I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
      The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
      11-25-2024, 12:53 AM
    • ohren
      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
      by ohren
      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
      The models launched in 2018 and 2019 respectively....
      09-08-2023, 05:24 PM
    • evilkitty
      Any idea what happened (wifi acted up)
      by evilkitty
      I have 2 access points, one a U6-LR and WZR-300HP running DD-WRT v3.0-r28444 (has had stable wifi since 2015)
      and i am trying to work on my PICO W and it suddenly would not connect and my computer had a very hard time connecting and my dad had been complained about his phone connecting
      so i ran a wifi scan script on the pico and it just hang for several seconds and found nothing, normally it would spit out every AP in under a second (both of mine and some neighbors)
      What i did was just install a U6-Lite that i had not gotten around to installing to replace...
      09-01-2023, 12:27 PM
    • karwan212
      Lenovo idea pad gaming 3, LA-L916P schematics request
      by karwan212
      Hi, Anyone have LA-L916P schematics, Please Share. Thank you!
      08-07-2025, 01:51 AM
