Hemp batteries/super capicators
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    has anyone researched this? It's interesting. Results are better than graphene at a fraction of the cost in lab tests. Maybe this could result in a miniaturization of regular caps at a fraction of the cost. Still has a long way to go even though, still it shows promise
    https://www.asme.org/topics-resource...tors-superfast
    worst case scenario, your car battery blows, cop pulls you over and your car smells like you've been hotboxing weed for days
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • Destroyer-Br
    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
    by Destroyer-Br
    I'm working on an Acer Nitro 5 unit with the following specs:
    • Motherboard: LA-J871P Rev: 1B
    • Model: Acer AN515-55-59MT
    • S/N: NHQ7JAL00403906A973400
    • SNID: 03902728734
    Initial Issue
    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
    04-17-2025, 08:18 PM
  • carrzkiss
    Cyberpower cps1500avr not charging batteries
    by carrzkiss
    Hello, all.
    Cyberpower Battery Backup Unit.
    I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
    When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
    In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
    Checking the voltage, it was down to 22v.
    I quickly removed everything...
    06-15-2024, 02:10 PM
  • howardc64
    Where do repair shops buy MB replacement batteries?
    by howardc64
    Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
    Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
    BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
    07-25-2024, 10:42 AM
  • Astonished
    Fixing the Charge Circuit of the Batteries of the DC Motor
    by Astonished
    Hi friends of electronics
    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
    Please help me fix this circuit.
    (the datasheet of the IC: https://pdf.datasheet.live/28...
    01-28-2025, 06:24 AM
