CPU Fans - Which, when, and why
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: CPU Fans - Which, when, and why
    what the?! u dont lube ball bearing fans! it just makes the ball bearing ring slippery and not grip on the shaft of the rotor causing grinding noises. u only lube sleeve bearings!
    anyway, that second twitchy fan definitely has a bad motor phase on one of the coils so the fan is considered bad unless u can repair the faulty phase like momaka said.
    as for that slow pulsing fan, clean off all the oil off the ball bearing ring and shaft with a paper towel. lol! those arent meant to be lubed with oil!
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Originally posted by socketa
      Yes, they are dual ball bearing fans
      One of them had dust bunnies inside, and i gave both of them an oil with hair clippers oil
      After giving them a spin by hand, they sound more noisey now!, so it does sound like (at least) a bearing issue.
      Yup, that's normal for any ball bearing fan.
      BBs don't do well with oil. They'll get even more noisy than before, even if the shaft doesn't slip in the bearing from the oil. I don't know why, but it's just their nature. When BBs fail or get worn, they can't be fixed. However, if you really are in a pinch to get a seized or hardly-turning BB going, then you can open them by removing their protective shield on both sides (there is a thin spring c-clip along the outer edge of the bearing holding the side shields.) Once removed, the shield will come off easily. With both sides off, spray the bearing with brake cleaner and wipe well with paper. Then you can drop some oil or grease in the bearing with a needle. After this, the bearing should turn freely.
      I don't suggest using repaired BBs for long, if at all. Once a BB has failed, it's just time to replace it.
      For this reason, I bought a bag of cheap bearings from China as an experiment (10x bearings for $1 shipped). Quality is dubious on all of the bearings, of course, and about half of the ones I got were just as noisy as the failed bearings they were meant to replace. But the other half that weren't, I was able to use and fix a few fans. Not really a worthwhile endeavor. More of a curiosity if that would fix my fans and because I like saving things from getting trashed. So far so good with the few fans I fixed, though they haven't seen that much use.
      Plugging them into 12V supply: one fan spins slowly and pulsing (about every 2 seconds) and has a rumbling feel to it.
      That one definitely sounds like a failed bearing.
      The other fan just twitches and will do a revolution if i turn the fan to either two of the four (opposite) positions, that the fan can rest at. If it lands back on one of those positions it will go again, untill it lands on either of the other two positions, where it will just twitch.
      That one either has a bad (open) winding somewhere or, more likely, bad winding driver transistors/IC. If windings are good, replacement driver transistors/IC may bring the fan back to working order. Not really worth it. But if you are curious...
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 661
        • samsara
        i wiped all of the oil off of the bearings and shaft, then swapped the bearings, spring, c-clip. and fan of the twitcher into the one that was going slow. Spins really nicely by hand (no rumbling, or hissing sounds of friction), but when powered by a molex connector, it still goes slow (or just twitches when plugged into the board).
        • socketa
          Asbelowsoabove
          • Jun 2014
          • 661
          • samsara
          Can anyone say if the missing component on this fan would likely be a NTC thermistor?
            • 31140
            it's very small, whatever it is - a thermocouple?
            https://www.amazon.com/Delta-AFB0712.../dp/B00U6V9S0Q
            • socketa
              Asbelowsoabove
              • Jun 2014
              • 661
              • samsara
              #26
              i measured one on a similar fan, and heated it up a bit with a hair dryer - the resistance went down as the temp went up
              7k to 4.6k
              it's a black SMD
              lots of photos that look like that come up when searching for smd NTC thermistor, but none came up for thermocouple
              looks like it's temperature related because of the gap in the board
              10k NTC thermistor?
                • 31140
                it's not SMD - look close at that photo
                it's a wire-ended bead mounted off the board to get the airflow - probably how it got knocked off.
                • socketa
                  Asbelowsoabove
                  • Jun 2014
                  • 661
                  • samsara
                  #28
                  here's a better photo of the same model fan
                  https://www.elecok.com/media/catalog..._tmp_img_2.jpg
                  that's an SMD component, and it's not mounted off of the board,
                  the split in the board exposes the black rectangular body to the air
                    • 31140
                    then they had 2 designs
                    • socketa
                      Asbelowsoabove
                      • Jun 2014
                      • 661
                      • samsara
                      #30
                      that's still an SMD component on that photo
                        • 31140
                        i linked the wring photo, i had one with an axial wire-ended bead on it.
                        what does it do if you already have a pwm wire though???
                        which takes priority, the pwm or the sensor?
                        • socketa
                          Asbelowsoabove
                          • Jun 2014
                          • 661
                          • samsara
                          #32
                          when i plug the connector into the board, and start it up, the fan spins
                          at first, the speed seems to vary a bit, but it's close to normal
                          i get "'CPU fan warning" message after booting
                          shows zero RPM for CPU fan in the BIOS
                            • 31140
                            i dont think that fault is caused by the missing part
                            • redwire
                              • 3912
                              Zero RPM means the tachometer output (blue wire) is not working, the connector pinout matches the M/B?
                                • 31140
                                isnt yellow the tach?
                                • redwire
                                  • 3912
                                  The 4-pin PC fan standard has pin 3 as Tach, pin 4 as PWM.
                                  But the Delta AFB0712VHB fan pics has pin 3 as blue.
                                  • emil_t
                                    RTX3090 working fine but fans not spinning
                                    by emil_t
                                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                    04-12-2024, 06:54 AM
                                    Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                    This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                    09-07-2024, 05:50 AM
                                    Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                    09-07-2024, 05:00 AM
                                    Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                    Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
