My Avitar
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    My Avitar
    Now I want to change my Avitar but here is the issue. I don't have the original file for the one I'm using right now on my system anymore. Can I capture this file back from badcaps? If so, how?
    Mark Twain
    John Paul Jones
    Rod Serling
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Re: My Avitar
    Never mind.....I'm a dumbass. Its saved back to my PC now. "Save Picture As" is a good thing! Now I can work up a new one. It will be called "Da Snake!"
    Mark Twain
    John Paul Jones
    Rod Serling
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Stevedb
      Google drive missing back-ups and doesn't make back-ups anymore after reset phone
      by Stevedb
      Hi all
      I have anoying problem after resetting my blackview bv9900 phone doesn't find google drive my phone back&ups anyymore also doesn't make new back-ups from my phone anamore. Does anyone know why it happens and how i can fix it . I will not like to lose my data again. Also back-up button is grey out see picture.
      Regards Steve...
      07-22-2022, 03:37 AM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
      I am comparing them to a brand new one that I installed
      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
      I going to let it run for several days before I remount back on the wall next to the...
      09-05-2024, 06:48 PM
