PC motherboards without a 14.31818 MHz crystal
  • japlytic
    • Oct 2005
    • 2086
    On an Asus P8Z68-M PRO motherboard from, I could not find a 14.31818 MHz crystal anywhere; all of the crystals except the RTC crystal were marked with MHz integers.
    You may know this, but 14.31818 MHz was used in the original IBM PC (4.772766 MHz for the 5 MHz-rated CPU (divide by 3) and (on a video card) 3.579545 MHz for NTSC colourburst (divide by 4).
    So therefore (in my theory), it is easier to generate required clock frequencies (including the 100 MHz reference clock for PCI Express) with a crystal of a MHz integer than a 14.31818 MHz crystal - are all new PC motherboards going this way?
    • 31084
    Re: PC motherboards without a 14.31818 MHz crystal
    it's down to the PLL/clock generator they choose.
    i'm surprised they arent trying to use the 32KHz crystal!
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Looks like that's the standard HPET granularity frequency.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • mariushm
        • May 2011
        • 3799
        It's been a long time since computers had to use weird clock frequencies to get other frequencies by division or multiplication.
        Why would they use something chosen because it's ntsc subcarrier.. ntsc is not the only thing in the world.
        See https://en.wikipedia.org/wiki/Crysta...or_frequencies for common frequencies.
        You may still find some weird clocks for UART (serial ports) or on sound cards...
        You're more likely to find 12 Mhz with USB
        @RJARRRPCGP that varies, for example on my system it's 3.418 Mhz
        • RJARRRPCGP
          • Jul 2004
          • 6304
          I heard that the 3 Mhz one isn't HPET.
          See this thread:
          https://www.badcaps.net/forum/showthread.php?t=75378
          Arc A770 16 GB
          • pc_okay
            Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
            by pc_okay
            Hello friends,
            Its been a while, i wish you an happy new year 2025 !
            I have this laptop doesn't start, power light up a second when pluging USB-C charger.
            Laptop take 0.11A.
            All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
            I get no oscilation on XTAL 32.768 KHZ
            Battery is not charging but charging led is here.
            PCH heat at 30° approximatively. (with no heatsink)
            I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
            It's a 2 pins Crystal.
            01-13-2025, 09:26 AM
          • OakleyDAR
            Zotac GTX 1050 Ti Mini ZT-P10510A-10L Replacement Crystal
            by OakleyDAR
            HI,
            I'm looking to replace the 27MHz crystal on this board as it isn't generating the signal. I thought it would be easy to identify a suitable replacement as there are clear markings on the crystal, but it appears I was wrong as Google gives nothing. Bad photo attached, but it has X27.0000 and 16AP1 on the casing. It appears to be a 3225 package, but looking through suppliers there are lots of different things like capacitance, tolerance, active or passive, etc. that need to be considered. Could anyone help identify a suitable replacement please?
            Thanks....
            04-21-2024, 03:07 PM
          • Keshenatech1
            Question on microprocessor crystal oscillator circuit
            by Keshenatech1
            I'm troubleshooting a reel controller board for an IGT slot machine. The digital section seems to be dead. There is no USB communication, PC or utility program for flashing firmware do not see it but they do see good/working boards. I noticed the waveform on the crystal is very erratic/asymmetrical/glitchy on the bad one compared to the nice even waveform on a good board. My question is would this most likely be caused by a bad crystal or something gone bad in the circuit loading it down? I'm attaching a couple pictures of my scope probing the good and bad boads.
            02-26-2024, 11:05 AM
          • qwerty99
            Xbox 1.6 Motherboards and Polymer Capacitors
            by qwerty99
            Hello!
            I need to change the capacitors on my three original Xboxes.
            Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
            The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
            The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
            I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
            06-26-2022, 12:53 AM
          • Foetuss
            Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
            by Foetuss
            Hi all
            Hope this is in the correct place.
            I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
            Could use some double checking to see if I'm not doing something stupid .
            Pictures of the boards are attached.
            What I will be replacing with what : (planned)
            Soltek Golden ::
            4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
            6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
            01-18-2025, 11:44 AM
